Hey all, real quick..
The TPS on my Euro R swap is busted(the connector). I have good wireing and machining skills. Werd on the street is I have to buy a whole throttle body to get a new sensor. Can anyone point me in the direction where I may be able to purchase a new sensor by itself??? I'd rather like to avoid shelling out 500 or so bucks for a new TB. If I could just get the sensor, it can't be that complicated to install(it's a pot with a lever, I mean, c'mon...). Please let me know asap. The engine is to go in on valentines day. So I need a TPS for a 2001 H22A __________________
95 Accord Euro R Hybrid T series 5 speed with LSD No boost, No bottle, Pure throttle. Accord of Doom: |
#2 | |
HOWEVER - You can salvage TPS sensors from other t-body's. Honda was smart in using the same TPS sensor for about 90% of their cars. I had one, but it is gone now. They sell for approximately $50-100. __________________
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a> |
WRX Sellout
Ride: 2002 WRB Impreza WRX
True, but for a swap, he'd probably want an adjustable one, which (as far as I understand) only came on JDM engines.
This space left intentionally blank. |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
They are all adjustable, JDM TB's come with screws that hold the TPS in place while USDM TB's are rivetted inplace. You can have the rivets drilled out a USDM TB, but don't go where I did, they charged me $80 for it.
![]() __________________
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
#6 |
The JDM TPS is exactly the same and the USDM, the difference is on the TB. It is how the TPS is mounted to the TB.
#8 |
Yes fellas, thank you. I already solved my TPS problem(no coversheets here.) I just unscrewed my jdm one and saw how it worked. I'm just gonna rip the one off my F22 when it comes out. Thanks for the info though. Stupid Honda, why the fuk not just sell them individually?
#9 |
because they need to re-calibrated to work on a different TB
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#10 |
which you can do your self if you have a volt meter.
| ECU Pinouts | pissedoffsol | Reference Materials | 4 | 11-21-2007 10:46 AM |
| Crx b16 problems | b18c1civic97 | HYBRID -> ED-EF / DA | 19 | 05-07-2007 02:53 PM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| T.P.S. Throttle Position Sensor | superstreetb16 | HYBRID -> ED-EF / DA | 3 | 02-17-2004 11:07 AM |
| 85-87 ECU Error Codes | pissedoffsol | Reference Materials | 0 | 09-28-2002 01:29 PM |
