can a bad dizzy cause backfiring
Old 07-19-2005, 12:22 PM   #1
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
well when i had my cam seals replaced the mechanic apparently put the dizzy on wrong the first time. it wobbled in circles! After ''fixing '' the problem it still had some play. So he said all it needed was the 3rd bolt and i should prolly replace the dizzy later on. Ever since then, it back fires at hot whether temperatures. It back fires in between shifts and when i let off the throttle. COULD THE DIZZY BE BAD? Everything else seems to be fine as far as my 02 sensor and timing
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 07-19-2005, 02:15 PM   #2
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
The rotor wobbles or the whole damned thing wobbles??
It could certainly cause backfiring.. The dizzy tells the plugs when to spark, if its wobbling it couldn't possibly be sparking perfectly..
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 07-19-2005, 02:32 PM   #3
Taco15's Avatar
Ride:  chevy s-10
myspace
alright you cant see it wobble since it's tighten down really tight. but if you put you hand on it you can feel the slight play inside the dizzy. I guess i'm buying a new dizzy. thanks for the reply man
