can someone do me a favor? (simple wiring question and speedo question)
Old 03-29-2007, 10:39 AM   #1
Ride:  RX5.7 Civic LS and Teg Ls
Rep Power: 25 civiclxb16 will become famous soon enough
Send a message via AIM to civiclxb16 Send a message via Yahoo to civiclxb16 myspace
Default can someone do me a favor? (simple wiring question and speedo question)
Ok guys and gals my speedo is not working, and i have a CEL for my vss. Now i have done 4 vss's two gauge cluster and still same thing. I took my cluster out and put it in my buddy's civic and it worked fine, so it comes down to my connector for my vss. So i have two questions!
1) can someone tell me what rpms you are at when you are at 45 mph on a ls tranny in 4th gear please?
and
2) if someone has a eg can they please tell me what pins the three vss wires are on the shock tower please?
this is my first eg and i have not done much work on it yet so i don't know the shock tower pins yet. or if someone can tell me what the three colors are i know one is a ground. thanks!
Check Out My Car Club
www.HighRevCustoms.com
and join the forums
this is what happens when you are bored out your mind!!:|
my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg
civiclxb16 is offline   Reply With Quote
Old 03-29-2007, 11:12 AM   #2
Rep Power: 16 killercannible will become famous soon enough
Same thing happened to me, you will probably laugh when you realize what it is. If any water (at all) has ever gotten in the vss plug the pins rust out very rapidly. Look at your plug and i will guarantee one or more of the pins is broken or coroded.
Got my swap!!! Needs to be faster.
killercannible is offline   Reply With Quote
Old 03-29-2007, 11:21 AM   #3
yeah i am about 90% sure that is my problem that is why i want to do an Ohms reading to see before i start cutting and pasting
and join the forums
Speedo Cable Question CReX123 General Tech and Maintenance 0 08-23-2004 12:19 PM
Speedo Cable, B18A in CRX Question CReX123 General Tech and Maintenance 2 07-07-2004 02:03 PM
