can someone help (revlimiter problem)
Old 04-02-2007, 04:44 PM   #1
Rep Power: 6 jdmh22a is on a distinguished road
Wink can someone help (revlimiter problem)
ive just swapped in a h22a into my civic with a p13 ecu . the thing is the revlimiter kicks in at about 6800 - 6900 , im thinking this isn't right because i have seen them rev to about 8000 stock . has anybody else come accross this ? or have any ideas .
thanks
jdmh22a is offline   Reply With Quote
Old 04-02-2007, 05:43 PM   #2
AHHVTEC's Avatar
yea theres something wrong try swapping out the ecu and see what happens
Old 04-02-2007, 06:35 PM   #3
yeah im trying to find another p13 . have this happend with you then ?
Old 04-02-2007, 06:38 PM   #4
AHHVTEC's Avatar
nope never happend just plug a p72 or a p30 up and see where it redlines with those
Old 04-02-2007, 06:46 PM   #5
yeah worth a try . they are obd1 arn't they ?
Old 04-02-2007, 06:48 PM   #6
AHHVTEC's Avatar
yup, thats what i use on my h22a the only thing is the p30 will not work your butterflies but the p72 will i just took my butterflies out so it didnt matter
Old 04-02-2007, 06:56 PM   #7
il be getting a skunk 2 inlet manifold in two weeks so that will be ok , the p30 and p72 are for smaller engines yeah ? they probably have diffrent fuel maps i expect . at least il see if it redlines higher
Old 04-02-2007, 07:05 PM   #8
AHHVTEC's Avatar
i put the p30 on mine because my p13 was for a auto tranny and i got sick of seeing the check light on, but it run fine with me
Old 04-02-2007, 07:09 PM   #9
i got a code for my ELD thats drivin me nuts but thats about it my ecu cam off a manual
Old 04-02-2007, 07:10 PM   #10
AHHVTEC's Avatar
what code number are you having
Old 04-02-2007, 07:10 PM   #11
does u'rs still make the same power with the p30 ?
Old 04-02-2007, 07:11 PM   #12
20
Old 04-02-2007, 07:12 PM   #13
AHHVTEC's Avatar
yup thats it, slap out the ecu and see if that helps it should be fine after that
Old 04-02-2007, 07:21 PM   #14
yeah cheers il try that fucker
Old 04-02-2007, 07:22 PM   #15
nice 1
Old 04-02-2007, 10:40 PM   #16
V8 Killer
Ride:  98 Civic HX/SI Hybrid
Rep Power: 6 KuruptedKustums69 is on a distinguished road
i have a 98 civic hx and i just did a b16a swap from a 99 si and im having the same problem my rev limiter should rev to 8000 but mine hits at 6400?
KuruptedKustums69 is offline   Reply With Quote
Old 04-03-2007, 05:48 PM   #17
its a bitch in it , im going to try what aahvtec sugested soon as i find an ecu . the car still goes like fuck
Old 04-03-2007, 09:02 PM   #18
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
do NOT run a p30 or p72 on an h22 unless its been chipped and has a custom program on it.
Not only do h22's have different sized injectors than the b18 and b16, the fuel maps are very wrong for it.
If you are throwing a code, fix your code first. There is 0 use in diagnossing a rev limit problem while you have codes showing.
ELD is wiried into the distributor wiring harness and has nothing to do with automatics, if that was the implied reference.
trace it down and make sure its wired in correctly.
Old 04-03-2007, 09:14 PM   #19
AHHVTEC's Avatar
yup sol is right mine is chipped
Old 04-03-2007, 10:56 PM   #20
Rep Power: 6 91civicnut is on a distinguished road
where can i find a cheap obd1 harness for a 92 1.5 vtec?
91civicnut is offline   Reply With Quote
Old 04-04-2007, 01:07 PM   #21
RETIRED
Rywire - Online Store might have what you're looking for.
Old 04-04-2007, 05:32 PM   #22
my car is a manual , i just mentioned my ecu came off a manual because aahvtec said he used a p30 because his p13 came off an auto. i thought the distributer wiring would be the same because my car and engine are obd1. ive tryed a different fuse box under the hood because the ELD is a sealed unit in the fuse box . do you think that high ELD voltage could be the problem with the rev limit ?
Old 04-05-2007, 12:21 AM   #23
AHHVTEC's Avatar
the p30 will plug up but mine was chiped for the h22a
Old 04-05-2007, 12:27 AM   #24
HONDA 4 LIFE
dbone_vtec's Avatar
Ride:  EG drag w/ B18
Rep Power: 8 dbone_vtec is on a distinguished road
check the vtec pressure switch "D"
dbone_vtec is offline   Reply With Quote
Old 04-05-2007, 01:03 AM   #25
AHHVTEC's Avatar
a pressure switch wont cause that
engine start problem LJK ECU's, Electronics, and Tuning 3 01-02-2007 04:47 PM
engine start problem LJK Civic and del Sol - EG and EK 0 12-17-2006 05:57 PM
power shifting...3rd gear mozzandherb General Tech and Maintenance 10 10-25-2005 08:07 PM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
Electrical Problem With My 1986 CRX Si The_MATRIX General Tech and Maintenance 0 06-17-2004 06:08 PM
