Check Engine light coming on
Old 06-14-2004, 02:10 PM   #1
Rep Power: 12 hondaflr is off the scale
Talking
I have a 1995 accord exr with a 94 prelude h22a, im having a problem with check
engine light coming on either when vehicle warms up, or when at a steady speed and stays on. the problem im having when i want to go check the code, is once i turn the vehicle off, then turn ignition on, check engine disapears, im wondering if computer stores the code, or if it erases, and if i can check it while vehicle is running. hopefully i can get sum answers, there is also a slight stumble when check engine light is on, but barely noticable. what can i do? thanks
hondaflr is offline   Reply With Quote
Old 06-16-2004, 06:16 PM   #2
Rep Power: 17 CRseX84 is off the scale
Send a message via AIM to CRseX84 Send a message via MSN to CRseX84 Send a message via Yahoo to CRseX84
yes u can check it when the engine is running. but the CEL will turn off after 3 sec, when u turn ur ignition on... u have to connect the 2 leads in order to get the code when the ignition is on.. good luck
Tyler
CRseX84 is offline   Reply With Quote
