Ride: '92 Civic CX
how do you wire in a 4 wire o2 sensor into a 95 civic cx? using a p28 ecu. pin locations etc.
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
its part of the wiring harness....only the vx requires going from 5-wire to 4-wire o2 sensor.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> |
what do you mean its part of the harness?
i used the harness that came with the engine as a guide. the pin locations for 2 of the wires can be found in the reference section of this site. the other 2 are grounds. __________________
.....deagle..... |
#7 | |
Ride: '92 Civic CX
#9 |
RETIRED
right- the cx is a one wire.
simply pick up a z6 or similar o2 sensor with the wiring. there are 2 balck wires, a white and a green if memory serves. |
#10 | |
Ride: '92 Civic CX
#11 |
RETIRED
im not sure. there is definitly not a chassis ground on the o2. it goes into a harness back to to ecu- so im assuming there should be a pin for it. That, or it meets up with other grounds.
the other black wire is the heater wire i belive. |
#12 |
Ride: '92 Civic CX
my girl has a 94 civic ex automatic. Will the pin locations of an automatic p28 be the same for a manual (as far as the oxygen sensor is concerned?) I'll try to trace the wires back to the ecu and let everyone know. But when looking at the p28 ecu pinout chart in the reference section. I dont see where they could go.
#13 |
Ride: '92 Civic CX
so here's what we know so far... and please... correct me if i'm wrong.
white wire on o2 sensor is the primary signal and goes to pin D14 (sure) green wire on o2 sensor is the heater for the sensor and goes to pin A6 (pretty sure) so where do the other two black wires go? anyone care to take a look for us? __________________
#14 | |
allow myself to quote myself
.....deagle..... |
#15 |
RETIRED
im not so sure the 2 blacks are grounds
when i put my header on, i cut the harness to re-locate the o2 down to by the cat instead of in the runner. now, when i put it back together, i had connected the black wires wrong. the car ran for about a min, and then died.... just stalled right out- CEL. It was a 50-50 shot, and that was the #1 thing that i thought could have been wrong, so we swapped the two balck wires. its ran ever since. now, if they were both grounds, exmpalin the above. |
#16 | |
Ride: '92 Civic CX
#18 |
Ride: '92 Civic CX
which ground circuit? where exactly?
#19 |
Ride: '92 Civic CX
this came straight from an old sport compact car magazine on a Hot-To for b16a into 92-95 civ...
![]() __________________
#20 |
here
A6 = black under white wire A25=black under green wire D14= white wire D22 = green wire __________________
<a href=\'http://www.knology.net/~jediklc/\' target=\'_blank\'>My Webpage</a> <a href=\'http://www.geocities.com/DawgSol94S/Welcome.html\' target=\'_blank\'>Team Sol Georgia</a> |
#21 |
02 sensors and the CX engine.
92-93 = 1 wire 94-95 = 4 wire __________________
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a> |
#22 | |
Ride: '92 Civic CX
#23 | |
Is your 95 a federal or california car? Maybe there is a difference. __________________
#24 |
I just swapped my CX on Saturday and I am dealing with this now and it is killing me! My 94 CX is a federal car, and it is one wire 02 sensor, the D16Z6 I put in is 4 wire, I think I can figure it out with all the info here, and hopefully I can get it to run now!
-Matt __________________
-Matt 2000 Civic EX Coupe 1990 Mustang LX 5.0 2002 Explorer Eddie Bauer |
#25 |
For anyone interested the 94 CX firewall harness is pre-wired for a 4 wire 02, so if your using a VTEC engine harness the 02 portion plugs in at the strut tower, you only need to run VTEC, at least that's how my 94 CX is wired....
| 99-00 civic Si cluster swap into EF How To (pics0) | B18C5James | HYBRID -> ED-EF / DA | 30 | 07-11-2007 06:25 PM |
| o2 sensor on ls in a 92 civic hatch | lohonda | HYBRID -> EG-EK / DC | 9 | 12-18-2003 01:55 PM |
| B16a Sir2 92 Civic Cx O2 Sensor Wiring | realm730 | HYBRID -> EG-EK / DC | 2 | 06-05-2003 12:41 PM |
| 85-87 ECU Error Codes | pissedoffsol | Reference Materials | 0 | 09-28-2002 01:29 PM |
