code 22
Old 11-04-2006, 01:36 AM   #1
Ride:  90 civic lx w/b18a1 swap(daily driver),91 crx si w/c5 in it(on a 100shot).01 s2000 for the weekends
Rep Power: 12 redef91 is off the scale
myspace
Default code 22
91 crx si with type r in it, my car was throwing check engine light which code 22. which is vtec pressure switch i went to honda and bought a brand new one. car was fine for about a week then stupid check engine light came on again. once again code 22. is there something going here. i heard it could be the obd conversion harnesses. i use a p06 computer with a type r map.
redef91 is offline   Reply With Quote
Old 11-04-2006, 02:03 AM   #2
AHHVTEC's Avatar
i got the same problem and still havent figured it out and this has been 3 mounts for mine with no luck im starting to wonder if it s not the oil pump
P1457 code? hondadriver General Tech and Maintenance 8 09-27-2006 02:37 AM
Engines with the fastest piston speeds asmallsol Members' Lounge 10 08-25-2006 09:01 AM
code 13, got some general questions brian11to1 ECU's, Electronics, and Tuning 2 01-08-2006 11:17 PM
P1457 code help hondadriver General Tech and Maintenance 7 06-11-2004 09:43 PM
codes civichbwithb18a1 HYBRID -> ED-EF / DA 1 10-03-2003 03:24 PM
