Code 4 - Crank Pos. Sensor
Old 01-28-2003, 05:46 AM   #1
ballsweat is off the scale
Hi, I'm doing a D16z6 swap in a 5th gen HB, I got all the codes cleared except the crankshaft position sensor, or code 4. The computer is swapped to a P28, the distributor was swapped twice to correct it but noth8ing changed, I have a feeling the wiring harness is busted somewhere but I"m not sure. Does anyone have some advice for clearing this code?
ballsweat is offline   Reply With Quote
Old 01-28-2003, 04:32 PM   #2
Nobody has any idea?
Code 4 on the CEL........ no one has ever got that?
Old 01-28-2003, 05:06 PM   #3
hybrid4 is off the scale
on my 4th gen, i had to add the crank angle sensor wires to the plug at the distributor. i did the same motor swap but, dont know much about 5th gen though. just gheck to see if you have 2 blue wires at your plug. thats all i know to do, hope it helps.
hybrid4 is offline   Reply With Quote
ECU Pinouts pissedoffsol Reference Materials 4 11-21-2007 09:46 AM
Crx b16 problems b18c1civic97 HYBRID -> ED-EF / DA 19 05-07-2007 01:53 PM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 12:03 PM
Help (experts) Code 1 and Oxygen Sensor R6Elmo General Tech and Maintenance 2 09-07-2003 09:56 AM
85-87 ECU Error Codes pissedoffsol Reference Materials 0 09-28-2002 12:29 PM
