| View Poll Results: do you think this will be a success | |||
| yes and why |
0 | 0% |
| no and why |
0 | 0% |
| Multiple Choice Poll. Voters: 0. You may not vote on this poll | |||
im currently intrested in controlling 450cc injectors with a vtec afc.
im currently in the process of building and developing a n/a build for a h22a it will use stock usdm pistons (fully rebuilt with apr rod bolts and coated main & rod bearings). the motor will spin to 8600 rpm max. also i will be using a alterdcreations stage 2 ported head/ custom factory intake manifold work, and a 74mm throttle body. i will be using stock valve train(to compare a stock p13 cylinder head against my stage 2 head for hp referance). i know that the motor will max out the factory h22a injectors. will a vtec afc be able to control 450cc dsm injectors for my n/a build. in the future i will run crower (custom combo of stage 3 specs with more lift and the same duration)or skunk 2 camshafts. i will be using the stock valves. i also using a chiped poa ecu (ericks racing reprogram) at first this will be a cost conservative build with stock parts to get a referance for future upgrades. does the vtec afc have the capabilty to handle the first part of this engine capabilty test? also i will us dc 2 1/2 inch header , cat less exgaust / in future it will be a prospeed and2 1/2 in taper into a 3" exgaust. any ideas on fueling my first stage set up? thanks |
HS Troll...And Mod
Ride: 2001 Honda S2000
Rep Power: 254 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
yes it will control those injectors. i would only use the VAFC as a place holder though...get an obd1 P72 or P28 and get a real program for the engine instead of using an AFC Hack.
#5 |
HS Troll...And Mod
ive never heard of anyone using the accord ecu, and i neither hondata nor crome (the two most widely used tuning software) support the P0A.
Id look into picking up a p28. |
| Is the H22A swap worth it in an Accord? I say yes | HONDAPITSTOP | HYBRID -> BA-BB /CA-CD | 20 | 03-28-2008 12:02 PM |
| Apexi SAFC2 and 450cc injectors | nick32 | Parts: For Sale/Trade/Wanted | 2 | 03-08-2006 09:53 PM |
| DSM 450cc injectors | TeamUrbanChaos | Engine Building | 3 | 09-01-2005 02:32 PM |
| h22a injectors | SolPWR | Engine Building | 2 | 11-03-2003 05:25 PM |
| 450cc Fuel Injectors? | Slimtadder | Engine Building | 9 | 01-08-2003 06:17 PM |
