Crank sensor code !
Old 08-03-2009, 12:01 AM   #1
Greenhorn
Rep Power: 0 dubkiller is on a distinguished road
Default Crank sensor code !
I installed a new distributor on my 2000 si and now i have a check engine light and the engine wont rev past 3200rpm! The engine runs fine at a idle! Wondering if any one knows what i screwed up to get the crank sensor code?
dubkiller is offline   Reply With Quote
Old 08-03-2009, 12:10 AM   #2
Rep Power: 4 DBCustoms is on a distinguished road
did you possibly get your plug wires mixed up? that is if you removed them from the cap. did you have this code or check engine light on before replacing the distributor? if so most likely need to reset the ECU if you didn't. let me know the answers to these questions then we can go from there. also was the actual code?
Dave Estes (owner of) DB Customs & Automotive Repair
http://www.automotivecustomworld.com
Just check it out!!
http://www.dbcustoms.ws
Free people search
DBCustoms is offline   Reply With Quote
Old 08-03-2009, 10:38 PM   #3
tabKola's Avatar
Ride:  civic ek 4 door
Rep Power: 5 tabKola is on a distinguished road
There are a couple of sensors in the distributor that will trigger a code if they go out. Perhaps your new distributor is defective.
tabKola is offline   Reply With Quote
Old 08-21-2009, 10:59 PM   #4
Greenhorn
Rep Power: 0 a2tz is on a distinguished road
so i'm having a similar problem. 91 crx with a b16 swap. have always had the CEL come on...only comes on once car is warmed up...THOUGHT it was the vtec solenoid code, but vtec worked, and had no adverse affects that i could tell, so i never messed with it. well just recently it developed a new trick of having horrible "sputtering" basically, and wouldnt' rev past 3250, but i could go to that rpm in each gear. it got progressively worse (from doing it some of the time) to then completly dying as soon as it was started. throwing code 23 and 4, knock sensor and crankshaft position sensor. replaced plugs/wires/rotor/cap first, becuase i knew how and wanted to try it, still did the same thing....got a new distributor in. turns out the guy who did my swap, used...a im not sure distributor. but only the top bolt was holding it on, one bolt position had a...metal strap on it, to hold the bolt, but wasn't tight. turns out this is likely why it leaked some oil from that location....
Seems to work ok now. drove a half hour and it worked. my CEL still comes on, and throws the same codes, 4 and 23, but didn't experience the sputtering like before. this is really long, and may need its own thread, but i hadn't found anyone else with the same "3250" rpm problems. thanks in advance!
a2tz is offline   Reply With Quote
Old 10-31-2009, 10:39 PM   #5
Ride:  civic/tegra
Rep Power: 1 kidkg24 is on a distinguished road
Send a message via AIM to kidkg24
well honda dist. have a magnetic pick-up for a cam sensor in the dist. I would say if the code came after you replaced the dist. that the new one is defective. Warrenty it, and your check engine light sould go away.
kidkg24 is offline   Reply With Quote
Old 10-31-2009, 10:41 PM   #6
Ride:  civic/tegra
their is also a magnetic pick-up for a crank sensor in the dist. because honda, acura does not use a external crank or cam sensor.
Old 11-11-2009, 05:41 PM   #7
Greenhorn
Rep Power: 0 raymat54 is on a distinguished road
Default RayBoost
I'm having a similar issue with my car,it revs very lazy and i have an idle issue. I have a 95 EG6 SiR 2 with TCS and ABS. Code 9 came up and have been told by many technicians to change the distributor which i have done many times and still can't get rid of the code. The TCS light is also on.
raymat54 is offline   Reply With Quote
Old Yesterday, 07:26 PM   #8
Greenhorn
Rep Power: 0 king101 can only hope to improve
iv just bout a b16a vtech engine but it has no crank sensore on it but my old b16a vtech does is it possable to take the crank sensor of my old engine and put it on the new one and how would i go about dooing so if you could help that would b great thank you
king101 is offline   Reply With Quote
ls crank sensor? honda801 ECU's, Electronics, and Tuning 2 09-20-2007 06:21 PM
ERROR CODE P1162 : Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response GreenMcNasty General Tech and Maintenance 7 02-17-2007 03:16 PM
Crank Sensor Domi31 General Tech and Maintenance 7 04-14-2006 09:53 PM
code 4 ckp sensor b20izzle HYBRID -> EG-EK / DC 4 11-21-2004 12:04 PM
Code 4 - Crank Pos. Sensor ballsweat ECU's, Electronics, and Tuning 2 01-28-2003 06:06 PM
