d15b
Old 04-17-2007, 12:41 PM   #1
Rep Power: 0 asianboi89 is on a distinguished road
Default d15b
what is the best ecu i can use for my soch vtec? motor is going into a 89 civic si hatch.
asianboi89 is offline   Reply With Quote
Old 04-17-2007, 01:02 PM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 160 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
po8
Old 04-18-2007, 11:21 AM   #3
im wondering if im running a obdo ecu will it work? or do i have to get a jumping ecu harness to a obd1 ecu?
Old 04-18-2007, 12:14 PM   #4
HS TECH
AHHVTEC's Avatar
unless you changed it to obd1 your still obdo so yes i would change it to obd1
Old 04-18-2007, 12:41 PM   #5
so what your saying is that my cars better off with a obd1 ecu n order to run? if its still in obdo then the car wont run?
Old 04-18-2007, 12:43 PM   #6
this is what im confused of......i have a 89 si hatch with a d15b motor, obdo ls ecu, but a 95 si distributor, the car is all hooked up and itll crank but wont catch spark im wondering if its the ecu that causing this problem?
Old 05-02-2007, 12:06 PM   #7
anyway i found out what the problem...i got my car to sparkup and cranking but not yet running....do you know whats the problem?
Forum Jump
d15b vtec-e vs d15z1 believer General Tech and Maintenance 10 09-27-2008 04:29 PM
jdm d15b vtec? Panther550 Engine Building 2 05-16-2007 06:55 PM
D16z6 Head On A D15b Block (vtec) Swap Hondero Engine Building 4 02-27-2007 05:37 PM
can i swap parts from a D16 to a D15B evo8 HYBRID -> EG-EK / DC 1 01-05-2005 02:48 PM
JDM D15B SOHC VTEC LongBlock ** So Cal ** $400 drew95eg Parts: For Sale/Trade/Wanted 6 09-27-2004 02:23 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
