D16z6/p28 Wiring 94cx Hatch
Old 02-01-2003, 04:31 PM   #1
Rep Power: 16 Spyderturbo is off the scale
Hey guys, I have a 94 CX and I am putting a 93 d16z6 motor and tranny run by a 94 P28 ecu in it. I need to know what additional wires I must run, and where I can get diagrams on the ECU plug to connect. The motor came with the engine harness, will it plug right in, then I need to run 3 extra wires from the Vtec solenoid to the ECU and tap in at the pins in my CX connector? God I hope it's that easy
Thanks, Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
2002 Explorer Eddie Bauer
Spyderturbo is offline   Reply With Quote
Old 02-01-2003, 05:14 PM   #2
Rep Power: 17 hybrid4 is off the scale
Dude, as far as i've heard, you just plug it right in. The vtec wires might already be in your stock harness from the ecu to the bay. check it out and let me know.
<a href=\'http://www.cardomain.com/memberpage/799640\' target=\'_blank\'>http://www.cardomain.com/memberpage/799640</a>
check out my band @ <a href=\'http://www.12vne.com\' target=\'_blank\'>12v NEGATIVE EARTH</a>
88 dx hatch w/ d16z6
88 crx si y8 minime
88 crx si SOHC Vtec Z6
87 MR2
<div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'>2 wrongs don't make a right, but 3 hard lefts will!</div>
hybrid4 is offline   Reply With Quote
Old 02-01-2003, 05:45 PM   #3
I thought the VX and SI were the only hatches to have the vtec wires run. I know some 92 and 93 models had the vtec already ran but I'm pretty sure that by 94 model year the CX was not pre-wired for vtec.....that would be sweet if it was though
Someone else out there have any idea?
Thanks, Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-01-2003, 05:52 PM   #4
Even if, all you need to do is run 3 little wires and your set.
88 crx si y8 minime
87 MR2
Old 02-01-2003, 06:16 PM   #5
So it is just the 3 wires? I thought it was only three but I wanted to make sure. If I need to run them I need to figure out where they get run to on the harness
Thanks, Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-01-2003, 06:36 PM   #6
Rep Power: 83 Havok is an unknown quantity at this point
Send a message via AIM to Havok
These 2 wires run strait from the vtec solenoid on the head to the ECU, A4 and D6
The green plug is the oil pressure, the gray harness with the yellow/green wires is the vtec solenoid
CX are not prewired, you need to get a Z6 harness, or extend it and solder.
My skin is singed but it heals my heart
and with glowing pride I'll wear my scars.
I'm honored by your hatred!
She wanted love, I taste of blood.
She bit my lip and drank my warmth from years before.
Havok is offline   Reply With Quote
Old 02-01-2003, 06:45 PM   #7
Can I just cut the harness wire, extend it, then pin out the CX ECU harness, or are the plugs different. I got the P28 plugs and about 6 inches of wire when I got my ecu today....
-Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-01-2003, 08:11 PM   #8
Rep Power: 25 SixtySecondAssassin is off the scale
i used the harness that came with my engine as a guide to see which wires went in which slots in the plugs. you need to run all the vtec wires, and a 4 wire o2 sensor. go here for pinouts:
http://tech.hybridgarage.com/tech/index.html
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 02-05-2003, 08:30 PM   #9
Hey guys, I have a little confusion left on this subject. Okay, I am getting the D16Z6 engine harness with my motor, sorry I left that out before. Someone told me that they had done a swap on a CX and since they got the engine harness they didn't need to run any wires. I was under the impression that the harness that runs from the engine bay to the ECU was not wired for vtec and that I would still need to run wires. I'm totally confused now, but if all I need to do is plug my D16Z6 harness into the Firewall harness plug I will be thrilled. Sorry to re-hash what some may view as already answered, I just wanted to be certain on this....
I get the motor Friday! I can't wait to be rid of my 72hp CX motor!
-Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
b18c into 94 hatch. Wiring truoss HYBRID -> EG-EK / DC 7 01-13-2004 01:33 AM
Anyone here? 2000Si Members' Lounge 14 12-09-2003 11:55 AM
WIRING DIAGRAM 00 CIVIC HATCH RELCOMAN ECU's, Electronics, and Tuning 0 10-06-2003 11:08 AM
92 hatch obd1 with gsr wiring? Vtec Andy..... ECU's, Electronics, and Tuning 1 10-03-2003 03:15 AM
Hatch Wiring Issues - Please Help! 5genracer ECU's, Electronics, and Tuning 3 04-21-2003 11:24 PM
