diagnostic?
Old 02-04-2007, 03:44 AM   #1
can you say 260 whp N/A??
94_gs-r's Avatar
Ride:  94 inegra gsr
Rep Power: 11 94_gs-r is an unknown quantity at this point
Send a message via Yahoo to 94_gs-r
Default diagnostic?
i just put the engine back into my car after building the block i have put 100 miles on it and the check engine light comes on it feels weak and powerless also at no matter what rpm im in if i put the pedal all the way down it sounds like the vtec is trying to kick in, i want to check to see what codes im throwing but i cant find the plug... chiltons says its either above the ecu or center console way under the dash i couldn't find it. neither could my mechanic, i need to find that and put a conductor (like a paper clip) in there so i can read the codes... can you help me find it?
buy my motor!!! check out link.
http://hondaswap.com/parts-sale-trad...ression-93212/
94_gs-r is offline   Reply With Quote
Old 02-04-2007, 04:18 AM   #2
Banned
Ride:  95honda accord ex f22b1
Rep Power: 0 hondaburner95 is on a distinguished road
Send a message via Yahoo to hondaburner95
ok i totally understand you ... took me 2 months to figure it out ... if you sitting in the passenger seat.. look at the glove box ... directly under the glove box door will be two plug ins.... one blue with 2 wires and one orange with 3 wires... unplug the blue one jump the plug and the start dianogis.......that should set you straight ... is not on the floor... under door of glove box
hondaburner95 is offline   Reply With Quote
Old 02-04-2007, 04:25 AM   #3
94_gs-r's Avatar
Ride:  94 inegra gsr
ok i found them but there both blue but as you said one with 2 wires one with 3
now i jump it and how do i read the code.. is there a pattern?
Old 02-04-2007, 04:48 AM   #4
Banned
ok jump the one with a paper clip...with 2 wires... key in the ignition turn to acc where check engine lightcomes on .... wait and it will flash once than pause then flash twice than pause.... then the code begins.. count the number of flashes .. when it pauses that was the fist number of the code .. then it will flash again .. count those . and that will be your code ..... then it resets by using a code 12... the fisrt number of they code is the slower flash the second the faster flash.....
Old 02-04-2007, 05:23 AM   #5
94_gs-r's Avatar
Ride:  94 inegra gsr
does the problem have to be fixed in order for it to move onto the next one?
its telling my my knock sensor is bad, i took it out and its broke.. shipping for a new one will take a while though, how do i know if there are any other codes?
Old 02-04-2007, 01:19 PM   #6
Banned
well when the code is giving it will give all codes... not just one ....to reset the ecu.... some models rrequire to take out ecu fuse under hood... and some like my accord i have to take out the radio fuse ..... ecu should be 15amp and radio is 10 amp... but when the code is giving ... all codes will display then the restet code will occur..... one flash then pause then 2 flash
Old 02-04-2007, 03:37 PM   #7
94_gs-r's Avatar
Ride:  94 inegra gsr
so i had 2 short flashes followed by 3 fast ones, it would be my knock sensor, and it repeated that one about 7 times, so is the the only code im blowing?
Old 02-04-2007, 03:42 PM   #8
Banned
if thats all your that your getting than thats the only problem ...you should make sure that you buy a honda knock sensor and not a cheap aftermarket... you should be ble to get that in 3 days tops
Old 02-04-2007, 03:42 PM   #9
Banned
what ecu do you have ??????
Old 02-04-2007, 11:55 PM   #10
94_gs-r's Avatar
Ride:  94 inegra gsr
its a p72, i did some more reading and i guess my car runs like shit because its in safe mode
where 2 get cheap diagnostic scanner computer thingy stickyfusion ECU's, Electronics, and Tuning 8 01-18-2006 02:07 AM
Is This The Right Harness For Cel Diagnostic? Pics Hybrid93Hatch General Tech and Maintenance 1 04-18-2003 03:11 AM
