Distributor For A 97 Gsr Question
Old 05-30-2003, 12:45 AM   #1
Rep Power: 0 stolenteg is off the scale
I have a 94 integra gsr and I was trying to rig up a 97 gsr unit - the unit looked the same - bolted right on - the wire harness was seperated in two small harness vs the 94 gsr distributor which has one fat harness - so I broke the plastic on the small harness seperated the distributor harness prongs and turned the prongs up and down and it connected right up - it seemed that honda made the harness design different -two prongs pointing left and right instead of up and down - it seemed to work- the top plugged right up - the bottom was mickey moused but IMO it seemed to work- i'm in the middle of fixing my stripped integra - found a 97 at the junks took the ecu obd2 and bought a jumper but I have everything plugged up but the car won't turn on - it could be 2 things at this point - I had cut the harness up from my 94 unit before I had the jumper and tried to color match the obd1 harness up to a obd2 harness -but of course it had way too many wires - so I saughtered (spelling?) it back up - had two red and two blacks which I had to figure out which went to what harness on the obd1- kinda of took a chance and I think I have the reds okay - one was leading to an injector the other to something other sh!t - but the blacks I was wondering does it matter if I had them mixed up -because in my book it should them as if they lead no where - which give me an idea that perhaps there just grounds - holla back if any one has any insite -
stolenteg is offline   Reply With Quote
Old 05-30-2003, 01:27 AM   #2
Rep Power: 20 AllMotorMonster is an unknown quantity at this point
You're hosed tommy.....
Hosed....
Should have bought the right parts to begin with.
1- OBD1 ecu plugs can be purchased. I know, I sell them brand new for theft recovery cars, and I have the pins too.
2- The OBD2 dizzy is a little different than the OBD1 ecu. With some work they can be used as a replacement, but it's really not worth the time and effort to save just a few bux.
Just my .02
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a>
AllMotorMonster is offline   Reply With Quote
Old 05-31-2003, 03:41 PM   #3
okay it seems the distributor is cool... I think the issue is something to do w/ the jumper and me trying to hook up a obd2 ecu to an obd1 harness- so next thing i'mma do is call my boy over and use his obd1 computer (minus the jumper) and try to play w/ the switching the red and black wire - I think the black wire really doesn't matter they are both on the same smaller harness and seem to be only grounds- it's the red wires cause I try to turn it over and its seems to be close to sparking but it just doesn't happen -
90' HB DX w/d15, auto \ going to d16 ECU QUESTION lcompeau ECU's, Electronics, and Tuning 2 05-28-2004 10:25 AM
B18C1 build question meredith Engine Building 13 03-29-2004 01:16 AM
H22A ENGINE and PULLEY QUESTION kingmarc01 HYBRID -> BA-BB /CA-CD 2 09-23-2003 12:30 AM
QUestion on LS swap Hatchback 95 hybrid HYBRID -> EG-EK / DC 3 08-23-2003 03:24 AM
Basic turbo question zueke Forced Induction 6 10-28-2002 07:04 AM
