distributor question?
Old 09-09-2006, 05:09 PM   #1
Rep Power: 0 bobito is on a distinguished road
Default distributor question?
I have a 92 teg gsr{b17a1} with a p61 ecu, i also have a 2000 sir distributor, i have already swapped the coil[which had the same PN as thw one in my teg]and the cap[fit like a glove]and all the ignition wires.The OBD1 dizzy has 2 plugs and the OBD2 has one ,all the wires are the same color just integrated into one plug,Can anyone tell me if hard wire the obd1 to the2 will it work.Another thing will the shaft match up to my intake cam?If anyone can shine some Knowledge my way it would be appreciated
bobito is offline   Reply With Quote
