Do I need a 5spd ECU?Can I covert my Auto ECU to a manual?
Old 08-19-2006, 12:30 AM   #1
Ride:  94 Accord EX
Rep Power: 8 Accordian is on a distinguished road
Default Do I need a 5spd ECU?Can I covert my Auto ECU to a manual?
I have a 94 honda accord ex auto and I also have a beaten 94 accord dx 5spd. I am about 75% done with a tranny swap.. I am turning my 94 ex auto into a 5spd manual...I NEED help with the ECU Situation... DO i need to get a 94 EX 5spd ecu?? could I modifiy mine?(anyone know exactly what needs to be done?) can I just unplug my tranny computer...and jump some of the wires from the auto shifter?? I think thats what I will try advice please
Accordian is offline   Reply With Quote
Old 08-19-2006, 11:15 AM   #2
WHATS CRACKIN??
93vicb16a2's Avatar
Ride:  anything with 4or more rims tires optional
Rep Power: 14 93vicb16a2 is off the scale
i know u can with a p28 someone on here did it but i do not know about accords
93vicb16a2 is offline   Reply With Quote
Old 08-20-2006, 11:11 AM   #3
Ride:  94 Accord EX
bump?
Old 08-20-2006, 02:30 PM   #4
93delsolsi's Avatar
Ride:  Del Sol
Rep Power: 12 93delsolsi is on a distinguished road
Send a message via AIM to 93delsolsi myspace
How to Convert an Automatic ECU to 5 Speed Specs
First, let's find out if we have an automatic, or a 5 speed ECU. If you don't want to plug it in and throw code 19 (automatic trans lockup solenoid) to find out it is an automatic ECU, then look at the code on the side. If the second to last number is a 5, then you have an automatic ECU (for OBD-1 USDM ECUs). If the 2nd to last # is anything but a five you have an ECU for a 5 speed. If you have a JDM obd-1 ECU, look at the last 3 digits: 900 or 901 will be an automatic. If you were unfortunate enough to get an automatic ECU, then read on and learn how to cure all your problems. The following information was all obtained from Hondata.com and the picture was graciously borrowed from them as well.
For JDM Pr3/Pw0 ECUs: Move the jumper from R68 to R67 (both locations are to the left of the ROM) For USDM OBD1 ECUs (p28): Underneath the ROM there is a row of resistors labeled with RP__ . Remove RP17 and install a jumper across RP18. For JDM OBD1 ECUs: RP18 (in the same location as USDM) needs to be lowered in value from 2.4k to 1.4k ohms.
93delsolsi is offline   Reply With Quote
Old 08-20-2006, 02:42 PM   #5
Ride:  94 Accord EX
So! can I just convert my automatic ECU to a 5spd and then plug in back into my car and start driving my newly swapped 5spd car??
Old 08-20-2006, 03:55 PM   #6
93delsolsi's Avatar
Ride:  Del Sol
yes you can
Old 08-20-2006, 04:55 PM   #7
Ride:  94 Accord EX
SERIOUSLY?! uhhh ok, so what about the wirring though? to my 5spd? the VSS and the reverse wirring? and what about the shifter needing to be in park? or neutral so the car can start? and the intrusctions you posted don't tell me anything (esp. my ecu), how can I covert my 94 accord ex automatic ecu to a 5spd? it's the POA
Old 08-21-2006, 12:18 AM   #8
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 532 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
http://hondaswap.com/~pills/autotomanual.html
its all there... as where it was copied from above, but not for the accord ecu i'm afraid.
the easy way is to just score a 5-spd one from a junkyard/ebay/etc. but it can be done.
perhaps someone on Welcome to PGMFI can help?
Old 12-13-2006, 07:25 AM   #9
Rep Power: 0 dee double dash is on a distinguished road
Default lock-up solenoid 94 honda civic ex
what happends if that part fails
dee double dash is offline   Reply With Quote
94 accord auto to manual swap help Accordian Accord 10 10-22-2006 10:05 AM
D-series manual motor to auto tranny??? Teambypass HYBRID -> EG-EK / DC 6 07-13-2005 01:28 PM
auto to manual swap need help tphan4 HYBRID -> EG-EK / DC 11 04-02-2005 06:51 PM
Auto VS Manual ECU reckedracing ECU's, Electronics, and Tuning 6 06-14-2004 06:48 PM
Auto To Manual 94 Civic V-tech frontstreetracer HYBRID -> EG-EK / DC 8 05-19-2003 07:07 PM
