DOHC ZC turbo, ecu mods?
Old 01-29-2008, 07:41 PM   #1
joe_91zchatch's Avatar
Rep Power: 0 joe_91zchatch is on a distinguished road
Default DOHC ZC turbo, ecu mods?
I have a DOHC ZC, i am currently researching all the parts im going to need, one of the big ones is, what ECU and what programming is going to be the best at a decent price. I am not looking for something thats super boosted as i'm building as i go, i just need to know what to start with, currently i have a t3/t4 turbo kit with 38mm wastegate, 5-30psi adjustable. 2.5 inch piping inter cooler, with BOV. 2.5 inch downpipe, I plan on running a lower psi (6-10) as the motor is not ready for anything higher yet. I plan to install 450cc injectors also, a fuel pump if needed. i am in the middle of questioning wether or not to go with a zdyne ecu based on the on board boost control options, any info, or available write ups or parts lists would be great! thanks!.
joe_91zchatch is offline   Reply With Quote
Old 01-29-2008, 10:45 PM   #2
The Kicker of Elves.
Blanco's Avatar
Rep Power: 217 Blanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
You don't think you're going to just drop some generic answer in, do you?
You need to have the ECU tuned with something like TurboEdit.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 01-30-2008, 11:51 AM   #3
No, i plan on having it tuned, but i am trying to weigh out my options, as im clueless as to where to take it for tuning or what ECU to use for the DOHC ZC with a turbo- from what i read most of them can be updated, the only thing i've been told locally is hondata, still looking for a good local shop, but thats proving to be difficult.
Old 01-30-2008, 01:25 PM   #4
Blanco's Avatar
Why not get your stock ECU chipped and tuned? Check Phearable.net.
Old 01-30-2008, 02:22 PM   #5
excellent, thanks so much, thats exactly what i needed to read, another question before i jump into this, obviously i need a boost controller, but i am reading these have fuel and map sensor controls built into them, am i to believe i dont need to update my ECU if i am using a device such as the Gizzmo IBC G9020? heres a link Gizzmo IBC - Intelligent Boost Controller - G9020
this is my first turbo project, i am very understanding of honda mechanics, but never ventured into boost. thanks for your help and patience.
Old 01-30-2008, 05:21 PM   #6
Blanco's Avatar
Nope, a boost controller is exactly that. It doesn't take the place of tuning. What tuning does is literally change the fuel and timing maps inside the ECU to run the engine as efficiently as possible. Tuning costs $120-150 an hour and is the absolute best investment you can make for any build. In fact, most of the power and reliability are in the tuning.
Old 01-30-2008, 05:57 PM   #7
cool, appreciate the 411, sounds like i need to get an ecu and find a local shop - or start learning these tuning applications myself (ha) thanks for your help
Old 01-31-2008, 03:22 AM   #8
B
Administrator
B's Avatar
Ride:  m3, dakota
Rep Power: 157 B has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace
chipped/socketed pm6 with turboedit is probably your best bet for the money
B is online now   Reply With Quote
Old 01-31-2008, 11:22 AM   #9
in using a pm6, witch wouldnt be a problem i have a stack of them from building civics, is it not going to be an issue with the sohc vs dohc? i assume the chipping will adjust the fuel mapping?
Old 01-31-2008, 06:50 PM   #10
Blanco's Avatar
WTF dude? Did you not even read what I already said about that?
It doesn't matter what ECU you use as long as you get it tuned for YOUR engine. You will not be able to just drop in any stock ECU for what you're doing. If you want to do that, forget the build and leave your engine 100% stock.
Old 02-01-2008, 04:56 PM   #11
thanks for the clarification - no need for the attitude bro - ill take my questions elsewhere, scratch my comment on thanking you for your patience.
Old 02-01-2008, 05:21 PM   #12
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 134 BrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
The point of chipping is that you are able to reprogram a given ECU to run whatever your motor setup is. All you need to worry about really is finding an ECU that can easily be chipped and modified (the PM6 will work fine in your case), and not about what type of motor that ECU originally was paired with.
For example, the P28 is probably one of the most popular ECUs to use due to it's ease of chip-ability. People use it all the time for the dual-cam VTEC builds, even though it originally came paired with the single-cam D16Z6.
Hope that helps clarify things a bit...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 02-04-2008, 11:27 AM   #13
thanks brutal, makes perfect sense.
Old 02-04-2008, 11:44 AM   #14
Blanco's Avatar
Sorry, I ain'tcha mamma.
Old 02-04-2008, 12:21 PM   #15
you win - your cooler than me.
Old 02-04-2008, 12:33 PM   #16
Blanco's Avatar
*You're.
Old 07-18-2008, 06:32 PM   #17
Rep Power: 0 angelo0426 is on a distinguished road
Default dohc turbo
learn from me the dohc does not hold boost well i had my boost controller set at 8psi and down shifted the other nght and blew a hole in the side of my block so if you plan on boosting a DOHC ZC DO NOT DO IT WITHOUT A PRO TUNE and do not listen to anything about how easy it is to tune your self its not i am proof i have hole the size of my fist in the side of my block i have to get another motor now!
angelo0426 is offline   Reply With Quote
Forum Jump
Honda Civic B B16 B18 Cast Turbo Manifold Integra DOHC RSS-Bot Auctions 0 01-17-2008 11:03 PM
Building a Homemade turbo Kit jimboburgess Turbo Information 8 01-17-2007 07:12 PM
Boost & HP Level Turbo&Auto Forced Induction 56 09-13-2006 01:18 AM
Turbo Boosting B16A CRX, need more mods! XXHondaRacerXX Engine Building 34 08-03-2006 12:48 AM
1996 Civic DOHC Turbo Hatch tdehnel Vehicles: For Sale/Trade/Wanted 4 11-11-2003 08:21 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
