| | LinkBack | Thread Tools |
| | #2 |
| Regular Member w/ Cheese Join Date: Aug 2006 Location: NW Indiana
iTrader: 0 / 0% Ride: 2000 EJ8 w/ SiR-II
Rep Power: 73 | The IAB is good for power! It stands for Intake Air Bypass - valve... At high rpms it opens up a secondary butterfly valve allowing more air to get into your head. If anything, disconnecting this will make you lose power. |
| | #4 |
Rep Power: 73 | i dont have an IAB on my car, but i would assume it would not open and remain closed if you disconnected the vacuum. The vacuum is the actual muscle behind opening the valve, there's an electronic solinoid that controls weather the vacuum reaches the valve or not. so no, it will stay closed. |
| | #5 |
| Honda Master Technician Join Date: Oct 2007 Location: NorCal Age: 28
iTrader: 0 / 0% Ride: 88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 | You will lose power if it is not functioning properly.. either in the high end or low end depending on if you leave it open or closed. It has nothing to do with the activation of VTEC. Either hook it up properly or buy a single stage manifold. If you want to know exactly how it works the search button is your answer. |
| All Swap Info for EF | Riceras | HYBRID -> ED-EF / DA | 2 | 02-07-2005 02:20 PM |
| ITR Intake Manifold on a B16a sir2 head | pissedoffsol | General Tech Articles | 0 | 01-11-2004 07:51 PM |
| Eagle rods and Je 11.5:1 pistons | tnsxsear | Parts: For Sale/Trade/Wanted | 20 | 11-03-2003 11:47 AM |
| dual stage GSR manifold | civicious | General Tech and Maintenance | 1 | 10-08-2003 02:15 PM |
