dpfi to mpfi problem
Old 10-12-2009, 03:37 PM   #1
Ride:  90 honda civic 2dr hb
Rep Power: 1 nwkdonblk is on a distinguished road
Default dpfi to mpfi problem
i know this has been covered 100 times but i went to move C1 to B10 which was empty ok but when i went to move C2 to B12 it had a white /red stripe in it
i was following the instruction and it was suppose to be empty and on the A plug A1 is yellow A3 is yellow A5 is red A7 is red now do i cut these and run wires to the injectors and then to the four wires on the resistor block then A15 to the fifth wire on the resistor block could use all the help i can get
nwkdonblk is offline   Reply With Quote
Old 10-12-2009, 08:30 PM   #2
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
Study this link
ECU Pinouts
Get a obd0 engine harness, strip it down, pull the fuel injector, fuel injector resistor box wiring from it, de pin @ tower side plug, get the cabin harness do the same but from shock tower to ecu. Depin and pin as much as you can. This way is alot cleaner and alot less soldering. Depin the injector wires @ cabin harness @ Ecu, swap c1/c2 with b10,b12 , run wires for distibutor sensors from distributor to shock tower plugs, from there to appropriate locations @ ECU to c1/c2. Run the fuel injector subharness from engine to shock tower, from there into their locations at the ecu-A1A3A5A7. It can be done easier, but im anal about wiring.
D15Beater is offline   Reply With Quote
DPFI to MPFI using P28 CRX-YEM HYBRID -> ED-EF / DA 5 02-27-2009 01:19 PM
DPFI to MPFI, engine harness problem? Walterronny HYBRID -> EG-EK / DC 3 09-20-2007 02:46 PM
DPFI to MPFI problem stivic ECU's, Electronics, and Tuning 0 10-29-2006 10:21 PM
DPFI MPFI SWAP problem fixed4 life HYBRID -> ED-EF / DA 0 10-06-2006 12:18 AM
re: dpfi-mpfi? gene HYBRID -> ED-EF / DA 4 05-19-2004 09:26 AM
