Dual point to Quad point
Old 03-11-2004, 03:30 PM   #1
Rep Power: 13 Hellbert is off the scale
ok i need help FAST! i need to know if i can convert d15 dual point injection to b18 quad point injection? if so, how do i do it? can i just front half the harness? that seems like the easiest way to do it if it will work.(take the harness from behind the ECU forward and replace it with the one from the b18.) any help is GREATLY appricated. thanks
Hellbert is offline   Reply With Quote
Old 03-11-2004, 04:11 PM   #2
Rep Power: 12 katman is off the scale
so I take it you own an 88-91 civic/crx DX or STD vehicle eh ?
"can i just front half the harness? that seems like the easiest way to do it if it will work.(take the harness from behind the ECU forward and replace it with the one from the b18.)"
Wishful thinking there....although I wish it to be that easy too but its not!
You cannot simply add on an MPFi engine harness on go, its more than just that. You need to add wiring for 2 more injectors and a few other things. I really do hate the DPFi->MPFi conversion with a passion.
but here's a few sites that can help out with your situation:
http://www.geocities.com/teampimports/fuelinj.html
(this one is real good)
http://www.fourthgenhatch.com/mpfi.html
katman is offline   Reply With Quote
Old 03-15-2004, 03:08 PM   #3
are the tail lights and fuel pump plugs the same on both? because the way its looking now we are taking the whole harness out of the integra and putting it in the crx. if i can save any time and not unhook the lghts and such im DEFINATELY doing that. if i can let me know befor i rip the whole crx harness out. i have about another week befor ill have the back half out. thanks, later
Old 03-15-2004, 03:20 PM   #4
Rep Power: 13 dinasty2003 is off the scale
are u trying to swap harnesses? the whole harness?like under the dash and all that?! and even back to the tail lights?!
dinasty2003 is offline   Reply With Quote
Old 03-15-2004, 07:10 PM   #5
Whats the difference between DX and STD Civics? Ive been wondering this for ever. I thought it was just hte transmission like maybe the DX was a 5 Speed, and the STD was a 4. Someone please help me out.
90 Integra Sedan
B20V 225 / 153
Any one want to grade this essay? jeffie7 Members' Lounge 30 06-16-2004 03:28 PM
Something cool about dual point injection! theB16tegguy Engine Building 20 11-26-2003 05:36 AM
dual stage GSR manifold civicious General Tech and Maintenance 1 10-08-2003 03:15 PM
Why Does The Gsr Have A Dual Stage Intake... MR.B General Tech and Maintenance 3 05-13-2003 07:51 PM
Tips For Setting Up A Killer Audio System pissedoffsol Members' Lounge 0 05-05-2003 02:51 AM
