Reverend Awptickes
Ride: 1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
So, now that I understand why my car has not been making the power it used to now that they've switched the gasoline to a 10% ethanol blend, what does everyone else do?
Here's what I figure: 100% Normal gasoline = 14.7:1 100% Ethanol = 9:1 So, 90% gasoline + 10% ethanol = 14.13:1 Right? So I should tune my stuff to 14.3:1 (with the appropriate modification for load) instead of 14.7, right? Anyone's input will be considered, even newbies'. |
usually when you start to add ethenol to the mix the engine likes a little more timing.. i tuned on e-85 and it was sluggish until i added roughly 8- 10 degrees to wot. of course backing it off a couple of degrees at peak fuel consumption cause it usually indicates peak torque without dyno tuning.... hope this helps a little
| Tuning | ctfinest | Members' Lounge | 2 | 03-15-2007 04:16 PM |
| Tuning ECM | ludecrasy87 | ECU's, Electronics, and Tuning | 0 | 01-05-2007 01:02 AM |
| D16 tuning | Roverguy | General Tech and Maintenance | 6 | 07-29-2006 08:50 PM |
| Tuning Ecu's | SupaMuna | ECU's, Electronics, and Tuning | 4 | 04-07-2003 04:00 PM |
| Tuning | mrfd3s | Forced Induction | 12 | 03-17-2003 01:17 AM |
