ECU part # question
Closed Thread
Old 01-09-2005, 12:23 PM   #1
Rep Power: 11 CivEk4 is off the scale
I am trying to find out what ECU is part # 37820-P72-A05 I currently have a 37820-P72-013 (JDM GSR OBD2a) and i'm looking for a backup for quick and easy replacement. What ECU is the A05? I've been trying to find a site that has all ECU part #'s listed which would be the easiest way to answer my question, but not having any luck with that.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-09-2005, 01:31 PM   #2
Rep Power: 20 AllMotorMonster is an unknown quantity at this point
I believe it is a 99-01 GSR OBD2B ecu, North America model
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a>
AllMotorMonster is offline
Old 01-09-2005, 01:49 PM   #3
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
From the ECU list in the reference section.
P72 2 yes 1996-2000 Acura Integra GSR
P72 2 yes 1996-1999 Acura Integra GSR B18C
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline
Old 01-09-2005, 03:55 PM   #4
P72 2 yes** 1996-2000 Acura Integra GSR
P72 2 yes** 1996-1999 Acura Integra GSR B18C
Where does that tell me what the part # is? Also where does it distinguish between JDM and USDM? There are many different P72 ECU's.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-09-2005, 06:10 PM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 901, A60, C50, C51, X30, A80, L50, L51
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02, G00, G01
Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52, L50, L51, G51
96-00 ECUs (P2E, P2P, P2J, P72)
5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
from the patterns we can learn the following:
first letter = country of orgin
J = Japan
C= Canada
A=USA
G=Europe
second digit, if 5, 7, 9 then ecu is auto usually
third digit denotes the version/variation
L = California emissions or typically high altitude states as well.
pissedoffsol is offline
Old 01-10-2005, 12:25 PM   #6
The above list still does not clarify whether or not it's OBD-1 or OBD-2a vs. OBD-2b and also does not list the A05 or 013 which are the two i'm trying to compare I know the P72-013 is the OBD-2 JDM GSR. Nobody knows where the Honda bible is that has the part # information? I've seen it somewhere before but cannot remember where I saw it.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-10-2005, 01:58 PM   #7
RETIRED
You can tell the obd by simply looking at it.
2B
2A
FROM top to bottom as pictured
Old 01-10-2005, 03:12 PM   #8
2B
2A
I am aware the difference can be seen by looking at it but i'm trying to be 100% sure because i'm trying to buy one and the only way to be 100% sure would be by the part #'s. I cannot trust someone to get it right by explaining to them how it looks. The JDM vs. USDM GSR looks the same for OBD-2a but the part # verifies the difference without error. I need the JDM OBD-2a because I only have 1 O2 sensor and if I get the USDM I will have a problem.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-11-2005, 08:08 AM   #9
Rep Power: 14 projekteg is off the scale
that IS A USDM 5 spd, p72, you don't need a honda parts catalog to verify this, if you look at what sol posted, you could have figured it out. there are no questions about it, it is usdm.............
chipped ecu's always in stock.....
projekteg is offline
Old 01-11-2005, 09:18 AM   #10
Ok, first of all I did say I did not have the ECU in front of me and I cannot trust someone to get it correct just by explaining over the phone what to look for. Although based off the part # information would tell me exactly what it is and distinguish between JDM vs. USDM, OBD-2a vs. OBD-2b, and do it without any error as long as the ECU is untouched internally. Also where in the information posted does it tell me that my current ECU (37820-P72-013) is JDM OBD-2a? The whole purpose of this post and the reason for asking for specific parts #'s is because I need to have a stock ECU that will plug right up without adapters and work with my 97' JDM B18C. I also need this ECU to be stock internally and I need to base this search off part #'s which is the sure fire way to get it right the first time.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-11-2005, 09:31 AM   #11
OK I found the information I needed for everyone's future reference here is the link to what I was looking for which tells me without a doubt by the part #'s which ECU belongs to which motor and will distinguish the difference between USDM vs. JDM and OBD-2a vs OBD-2b. I would like to thank everyone for their help though.
http://www.pgmfi.org/twiki/bin/view/Librar...DefinitionCodes
Based off of this list the only one that is compatible with my motor without modifying ECU or my current setup would be the P72-Q13 as long as it only requires 1 02 sensor. So therefore i'm pretty limited to what I can use as a stock replacement.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-11-2005, 01:35 PM   #12
it would be much easier and just as cheap to just get an obd2 -> obd1 conversion harness so that you can use any obd1 manual ecu, that way you're not so limited trying to find one particular ecu for 1 o2 sensor.
Old 01-11-2005, 03:24 PM   #13
Yeah, I know it would be cheaper and possibly easier but unfortunately I have to keep it stock and without OBD-2->OBD-1 conversion so that makes my options very limited now I guess. Oh well, time to hunt down another P72-013.
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-13-2005, 05:22 PM   #14
Rep Power: 11 seephor is off the scale
another P72-013? well could I say you are just in luck? I recently bought a JDM swap and got that ECU. Like yourself, I spent a lot of time trying to figure out exactly what ECU it was (obd wise) and yea I found out it was JDM OBD2a BUT, a big BUT that is, the ECU is considered OBD1 according to US standards. This is because there are a few things missing. The things missing from that ECU are of course the 2nd heated o2 sensor. the CKF (crankcase fluctuation sensor), the EVAP purge solenoid (emissions) and the VTEC pressure switch. some of these nonsense emissions components aren't used in japan so they aren't built into the ECU. I'm converting the motor to USDM spec which means I bought a USDM P72-A03 ecu (which I think is for a 97 gsr), so I won't be needing this JDM ecu anymore. The ECU looks visually like it's been through a lot but I'll refund you 100% if it doesn't work. And according to acura, a p72-A05 belongs to a 00-01 USDM GSR. My email is seephor@hotmail.com if you want to contact me. good luck
seephor is offline
Old 01-19-2005, 12:19 PM   #15
Well, I picked up a P72-013 off Ebay which appears to be in great shape for only $61 shipped. Couldn't have done a conversion harness and ECU for less than that.
B)
97' Civic HB
06' F-250 PSD
94' Integra RS
03' R6
CivEk4 is offline
Old 01-19-2005, 01:47 PM   #16
B)
wow, sweet deal i'll give ya 62 shipped for it
Old 09-02-2008, 11:52 PM   #17
Rep Power: 0 nitroso84 is on a distinguished road
i have the same problem i just got a 95 jdm gsr and i dont know how to tell if the ecu they sent me is jdm or usdm the number is a37820-p72-003 i have no leters except on the bottom right corner it says (as) wut does that mean? pls help and i know is a obd 1
nitroso84 is offline
Old 09-03-2008, 12:02 AM   #18
Ride:  94 Tegy
Rep Power: 0 tuco1power is on a distinguished road
can you plz help and tell me what engine this ECU belongs to P72-003
tuco1power is offline
Old 09-03-2008, 12:03 AM   #19
Ride:  94 Tegy
what motor this Ecu belongs to P72-003
Old 09-03-2008, 12:05 AM   #20
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
what the fuck n00bs?? read the date before posting damnit!
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is online now
Closed Thread
