ECU PROBLEM with check engine light
Old 12-18-2005, 10:23 AM   #1
Rep Power: 0 crxturbo9psi is off the scale
I have a b16 with a pr3 ecu and I'm getting a code thrown at me its 6 long flashes and 8 short flashes! what would that be? And the car spudders at like 5500 rpm. Maybe a bad o2 sensor? Im not sure someone help please
crxturbo9psi is offline   Reply With Quote
Old 12-18-2005, 05:45 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 137 reikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant future
myspace
Id say o2 or egr.
and after looking up the code...code 67 is all i can find that is close. And a bad cat (code 67) could also cause that problem.
Need engine Components? -- Call Us.
Tell them Fritts sent you and they will cut you a deal you will have to hear to believe.
reikoshea is offline   Reply With Quote
Old 12-21-2005, 04:38 PM   #3
where is the egr sensor? and I dont have a cat on so how could it possibly be that? [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
Old 12-21-2005, 05:41 PM   #4
HS RA
eg6sir's Avatar
Ride:  Le Car
Rep Power: 225 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace
i came up with a couple possible combinations with that code..
10 & 58
IAT...TDC sensor... but thats unlikly because its only on a V6
or
20 & 48
Electrical load detector.....Lean Air Fuel sensor (LAF)
DO NOT PM ME WITH TECH QUESTIONS!
Originally Posted by Celerity View Post
Nothing says class like Willie Nelson on your pussy.
MY For Sale thread
eg6sir is offline   Reply With Quote
Old 12-21-2005, 07:11 PM   #5
HS Troll...And Mod
reikoshea's Avatar
myspace
EGR is usually between the fuel rail and the IM. got a vacuum line that usually runs right on top of the fuel rail.
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
