Ride: 97 del sol si turbo / dd is a 95 eclipse gsx
ok, I new to this site, but not new to Honda's, I own a 97 del sol si that was turboed but do to financial reasons im putting the car back to stock. Im almost done my rebuild on the y8, but I have one issue remaining
The car came stock with an obd2 p28 which I no longer have. Now my question is can I use an obd2 p2p in its place or do I need to get another obd2 p28, The p2p are a dime a dozen but the p28 are rare to find and are extremely overpriced. any insight on this issue is appreciated, and If your going to try to tell me that Honda never made obd2 p28 don't post here |
#5 |
Nick Go FAST!!
Ride: 09 Cobalt SS/TC
You could get a obd2->obd1 harness and a obd1 p28?
www.BackyardTurbo.com |
#6 |
I just sold a obd1 p28 and a boomslang harness the car is being put back to stock.
Does anyone know if I can use a p2p instead of a obd2 p28 |
#7 | |
Ride: gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
the p2p is the ecu for the y8, therefore it will work
93' dx hatch jdm b18c - jrsc 8psi s300 440cc RC's |
#8 |
you get the BRAKE
Get the ecu that matches the engine. If the car is obd2 and the engine is obd2 than get the obd2 ecu for that engine. Keep in mind, you will need an obd2a ecu, not an obd2b.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#9 | |
Brutal Moderator
Ride: 97 Integra LS Coupe
![]() The easiest way to guarantee it will work the first time and run correctly is to just use the ECU that's meant for the motor. A P2P should be fine, just make sure it's an OBD2A ECU like LS_VTEC said... __________________
#11 |
Hey friends....
I want to this Honda ECU pinouts.... 37820-P8R-911 817-128350 PLEASE send is.... my email : cdsalwathura@gmail.com good bye.... |
#12 |
Brutal Moderator
Stop spamming. Start your own thread...
| help asap - intake manifold swap question | NEWBIEDAN | HYBRID -> ED-EF / DA | 1 | 12-18-2007 01:13 AM |
| Question about two wiring harness connectors/gauges | That Guy | ECU's, Electronics, and Tuning | 2 | 07-20-2007 02:12 AM |
| motor mount question and gasket question | 93integraxchic | HYBRID -> ED-EF / DA | 2 | 07-12-2007 01:50 AM |
| Clutch Question | slow1pt7 | General Tech and Maintenance | 2 | 05-12-2007 02:19 AM |
| Cylinder head gasket question | Speed Box | Civic and CRX - EF | 23 | 04-02-2007 04:48 AM |
