ECU Questions
Old 10-08-2003, 10:26 PM   #1
Rep Power: 12 Vtec Andy..... is off the scale
im ordering a h22a (jdm) complete change over..... whats the ecu? obd? i have a 92 civic hatch si with obd1 wiring will i have any problems .....Ineed help can you help me
THanks,Andrew
Vtec Andy..... is offline   Reply With Quote
Old 10-09-2003, 12:33 AM   #2
Rep Power: 25 SleEPeR_CRX is off the scale
what year h22a did u get? the will tell us what obd it is and what ecu it is.
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 10-09-2003, 01:08 PM   #3
its a 97-00 h22 motor
Old 10-09-2003, 04:34 PM   #4
Rep Power: 17 radnulb is on a distinguished road
Send a message via ICQ to radnulb Send a message via AIM to radnulb
DO NOT GET A ATTS TRANNY!!!
ATTS is that traction control system that came in the type SH preludes. Aparently, the ATTS transmission is not swap-friendly, particularly with Civics.
Wiring wise, it shouldn't be that big of a pain. USE THE STOCK Si HARNESS!!! Your Civic Si is already vtec, and already has a 4wire O2, so no surprises there. It would be a good thing for you to get the OBD2 engine harness with your motor, as you will need to remove the pins from your OBD1 harness, remove the pins from the OBD2 distributor connectors and then put the pins from your OBD1 harness in the correct spots on the pins of the OBD2 plugs. This sounds harder than it is. The helms manual will be your friend.
As for an ECU to run the thing, forget converting to OBD2. You can chip the P28 that came in your Civic Si to make it run http://pgmfi.org/phorum/read.php?f=42&i=86&t=86 a H22, or you can acquire a 92-95 P13 ECU ($$$) and add wires for knock sensor. If you are really worried about the IABs you can even make the P28 operate them. http://www.nitroburn.com/pgmfiwiki/index.p...php/AddIABToP28
PGMFI.org founder and DIY ECU tuning advocate
Just say no to rice...
radnulb is offline   Reply With Quote
Forum Jump
For B... Answers to Men's Questions 94RedSiGal Members' Lounge 9 03-21-2004 03:58 AM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
B18B questions AlphaCivic HYBRID -> EG-EK / DC 3 12-31-2003 03:33 AM
couple of ZC questions Rivan Engine Building 3 08-26-2003 05:04 PM
H22 Swap Questions DjMcPhatty HYBRID -> EG-EK / DC 8 05-30-2003 08:17 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
