Elecrical Load Detector! Help
Old 01-21-2008, 08:49 AM   #1
Rep Power: 0 elwood79 is on a distinguished road
Question Elecrical Load Detector! Help
I plugged a code reader into my 97 honda accord to see if there was anything wrong with it and it told me this..."electrical load detector circuit high input"
does anybody know what this means and if it is very hard to fix?
Please help, I have no clue what to do
elwood79 is offline   Reply With Quote
Old 01-22-2008, 12:54 PM   #2
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
ELD is in the distributor. check your timing, spark plugs, and perhaps use a better octane gas.
B is offline   Reply With Quote
Old 01-22-2008, 01:05 PM   #3
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
It also goes off due to a missed ground...as the time spent under the hood of the lude has taught me.
Check the big 3 grounds. (Valve Cover, Thermostat and Transmission)
Anime Informant
reikoshea is offline   Reply With Quote
Old 01-25-2008, 07:55 PM   #4
Thanks a lot for all your help, reikoshea and B, i had no clue as to what that meant.
Old 01-28-2008, 06:24 AM   #5
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
no!!! old~ish thread. the ELD is in the under-hood fusebox!!!
not in the distributor!!
Old 01-28-2008, 09:52 AM   #6
HS Troll...And Mod
reikoshea's Avatar
myspace
depends on the car.
kthx.
Anime Informant
Old 01-28-2008, 11:25 AM   #7
So what do i need to check for in the under hood fusebox? A bad fuse or something?
I have already changed spark plugs and wires.
Old 01-28-2008, 12:33 PM   #8
HS Troll...And Mod
reikoshea's Avatar
myspace
thats where the eld is/might be.
Anime Informant
Old 01-28-2008, 02:54 PM   #9
YBLEGAL's Avatar
myspace
well yeah as reikoshea says, might be. i'd say 99% chance it is. honda likes to keep it simple.
the bad news is, the ELD isnt a servicable part. it's integrated into the fuse box innards. you'll have to probably get a new under-hood fuse box. i dont know anyone first hand that's had it go bad. but ya...
Old 01-28-2008, 05:59 PM   #10
HS Troll...And Mod
reikoshea's Avatar
myspace
well it doesnt go out often, usually its an alert of something else, like the distributor or a short in the wiring.
Anime Informant
Old 01-28-2008, 06:09 PM   #11
YBLEGAL's Avatar
myspace
high input would lead me to belive a sensor is malfunctioning, outputting a value much higher than the ECU expected, or that the circuit expected. mmmaybe if you had a higher amperage fuse than what something is supposed to use. just some guesses.
check engine light problem? electrical load detector treysawyers19 Civic and del Sol - EG and EK 19 11-14-2009 11:45 AM
Electronic load detector iasdyk HYBRID -> BA-BB /CA-CD 0 12-21-2007 01:00 AM
Basic Tire Info pissedoffsol General Tech Articles 0 01-12-2004 01:44 AM
Wheel Max Load Rating SpyOneUSN Wheels / Suspension / Tires / Brakes 7 05-10-2003 01:07 PM
