Engine Check Light. Obd1
Old 01-17-2003, 07:52 AM   #1
Rep Power: 15 simonc is off the scale
The engine check light has appeared on our 1993 civic SiR.
According to Hondata and other sites, you can find out what's causing this by finding two blue diagnostic wires near the passenger footwell, short them out, and the check light will flash the problem.
Has anyone ever done this? If so, where do you find the blue wires, and how do you go about shorting them out? OR should I leave this to Honda?
simonc is offline   Reply With Quote
Old 01-17-2003, 09:53 AM   #2
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
its very simple... pull back the carpet on the passenger's footrest and you'll see the ecu on the right hand side. look for a plug with two wires in it and use a piece of wire or a paperclip to short it out. turn the car on and check your codes.
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
98 civic o2 sensor / check engine light malone68 NorthEast 1 07-12-2004 07:40 PM
Check light on EF9 hb with b16a swap Jdubspeeds HYBRID -> ED-EF / DA 12 12-25-2003 12:34 AM
Check engine light after air intake install grifter2162 General Tech and Maintenance 9 10-15-2003 03:48 PM
Wiring P28 ECU to CRX check engine light? vmk23 ECU's, Electronics, and Tuning 3 08-10-2003 03:34 PM
Check Engine Light Viperlocc_B18C1 General Tech and Maintenance 3 04-13-2003 01:27 PM
