Fuel Guage Doesn't Go Down Much
Old 07-17-2008, 05:07 PM   #1
05X
Rep Power: 0 05X is on a distinguished road
Default Fuel Guage Doesn't Go Down Much
I have a Civic SI Guage Cluster and I noticed that the fuel guage needle doesn't seem to be dropping much every time I drive. I have driven over 140 miles and the needle is still more than 3/4 and a little less than full. It's weird. Normally, I would be close to half tank by 140 miles. Also, I tried moving the needle manually, but it went back to where it was. It just started happening. I doubt I'm getting 40 mpg-more like 29 mpg. I have an LS engine by the way. Any ideas?
05X is offline   Reply With Quote
Old 07-17-2008, 06:09 PM   #2
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 10 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
the float in your fuel tank might be sticking
t3t4delsol is offline   Reply With Quote
Old 07-18-2008, 12:38 AM   #3
05X
What's a "Float" and how do I fix it?
Old 09-08-2008, 12:01 AM   #4
Ride:  95 Civic EX Coupe
Rep Power: 0 95EGCoupeVtec will become famous soon enough
myspace
the float in your fuel tank is what floats on top of the surface of the fuel in your tank and sends a signal to your gauge cluster to move the needle up or down. if the shaft that it moves up and down on is dirty/dry , then it will stick. it is located in the tank right by the fuel pump.
95 Civic DX Coupe: Mods
-D16z6 swap
-OEM Type R Lip
-Power Steering removed
-short ram intake
-header
-17" Oem Integra honeycombs
-GSR suspension
-rear lower control arms and tie bar
-5" tachometer, only for the shiftlight (got it for free)
-Vtack light, y0!(its a cheap temp and oil pressure gauge)
-I CAN HEAR MY VTEC, ITS LOUD!
Soon to have:
-new oem/racing clutch
-hi flow cat
-Black or titanium reverse glow gauges that go to 10k and 160mph (they look oem)
95EGCoupeVtec is offline   Reply With Quote
Old 09-15-2008, 12:34 PM   #5
Ride:  95 Accord EX Coupe 5 spd
Rep Power: 0 craiger is infamous around these partscraiger is infamous around these parts
It could also be the electronic looking thingy (sorry dont know the specific name) attached to the fuel pump. If you take out the entire fuel pump assemble you will see the float at the end, the arm that goes to the electronic thingy I am talking about. I have had this happen to me before. You might have to replace the entire fuel pump to fix this problem. Good Luck.
craiger is offline   Reply With Quote
Forum Jump
HELP:Air/fuel guage in red!! honda_tuner_2007 ECU's, Electronics, and Tuning 6 04-08-2007 06:05 PM
air/fuel guage crxjdm34 HYBRID -> ED-EF / DA 0 08-10-2003 02:24 PM
Air/fuel Guage Drenni General Tech and Maintenance 11 04-07-2003 08:39 PM
Air/fuel Guage In Zc? delsolty Members' Lounge 1 04-01-2003 12:48 AM
Air fuel ratio guage hatchproject ECU's, Electronics, and Tuning 6 12-27-2002 10:09 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
