Fuse Keeps Blowing WTF!!!!
Old 04-27-2004, 05:27 AM   #1
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
CAR:88 CRX Si
Everytime i turn on my headlights, the damn fuse for the corner lights and tailights keeps on blowing. I don't have a radio so i thought that was the problem because i know there is a hot wire that runs with the radio harness wires that only has power when you turn on the lights, so i taped off every single wire and that actually worked for about an hour then it blew again when i hit a bump in the road. so i figured the tape just came loose, so i did it again and i am still having this problem. anyone have an idea of where a wire could be grounding out?
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 04-27-2004, 09:26 AM   #2
Rep Power: 51 Slammed90Lude is an unknown quantity at this point
Send a message via AIM to Slammed90Lude
do you have white face gauges? either way, pull out the gauge cluster and find out if something it there is shorting- in my girl's integra (92) there was a short in the dashboard causing this, because teh gauge cluster and taillights are on the same circuit
Slammed90Lude is offline   Reply With Quote
Old 04-27-2004, 09:53 PM   #3
I'll be back...
i'ma go check that...have any other ideas???
EDIT:Stock Cluster*
Just finshed swap but keep blowing a fuse Cambo HYBRID -> EG-EK / DC 2 02-02-2004 11:37 PM
Fuse Problem darwins_vtech HYBRID -> EG-EK / DC 0 09-12-2003 01:03 PM
Blowing Clutster/tail Light Fuse SleEPeR_CRX ECU's, Electronics, and Tuning 5 06-11-2003 03:07 PM
Fuse Keeps Blowing hf hoe HYBRID -> EG-EK / DC 2 05-01-2003 02:58 AM
Blowing Fuse stud4u2c17 ECU's, Electronics, and Tuning 2 03-15-2003 01:20 PM
