#3 | |
no you need the 99-00 Si engine/ecu harness for it to work properly. Edit: The GSR engine harness stops in the engine bay, it will NOT connect to your 99Si ECU directly. This is why you need the 99Si engine/ecu harness __________________
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a> |
Edit: The GSR engine harness stops in the engine bay, it will NOT connect to your 99Si ECU directly. This is why you need the 99Si engine/ecu harness [/quote] well i can't find a 99si harness in dallas or on ebay. thats y i was wondering if i get the complete gsr obd2 engine harness then get a obd2-obd1 jumper harness and run a chipped p28 ecu for my b20vtec will that work? |
#5 |
No, it wont. I explained why.
#6 | |
