guage cluster issue
Old 03-24-2005, 08:07 PM   #1
Rep Power: 17 htrcivic96sir is off the scale
92 eg hatch CX---- guages work fine and so do CEL,SB,Shift lights. Problem is ever since I bought the car the guage cluster has lit up once for all of 2 minutes during my intire time of own3rship. Checked fuse, it was good but replaced it anyway. Shift light comes on when Head lamps are off but not when they're on. Havn't pulled it apart yet , but I'd like to know where to start if anyone else has had this issue before. Thanx for any help.
NOTE: when I purchased the car, the stereos' harness had been hacked up but i checked it out and everything seemed to be buttoned back up ( butt style connectors) and i even installed a new stereo that works great on the existing repaired wires.
<div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'>&quot;ignorance can be taught away, but stupid is forever.&quot; ( seen it on judge Joe Brown)
</div> Black on black 2003 Chevy S-10: traded in
Red 1992 Eg hatch CX: D16Z6-T ; project ABANDONED, sold car, motor for sale/ trade<a href=\"http://www.hondaswap.com/forums/index.php?showtopic=70367&st=0&gopi d=691924&#entry691924\" target=\"_blank\">here</a>
Currently drivinig;
2003 s2000&gt; 18&quot; falken circuit specs
1994 teggy LS&gt; ricetastic pipe and blue badges ( purchased this way)
htrcivic96sir is offline   Reply With Quote
Old 03-24-2005, 09:08 PM   #2
Rep Power: 12 Boosted4dr is off the scale
I would start looking at the hacked up wires.
Check the wires that go to the Dimmer see if they are connected. From the switch to the cluster etc. The problem w/ my cluster lights was the dimmer switch was junk.
Try to hit that switch a few times and that will let you know if there is a wire loose or the unit itself is destroyed
Boosted4dr is offline   Reply With Quote
Old 03-24-2005, 09:11 PM   #3
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
I was just about to say that.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 03-24-2005, 11:29 PM   #4
Rep Power: 18 TWISTEDIMAGE is off the scale
Send a message via Yahoo to TWISTEDIMAGE
check tail marker lights just make sure they work
hi
TWISTEDIMAGE is offline   Reply With Quote
Old 03-25-2005, 11:06 PM   #5
twisted- i am having trouble with the front right corner lamp, its "reverse blinking"... instead of flashing on when im turning it flashes out... but the bulb is in right because it has offset lock tabs on it so they're idiot proof.
boosted4dr- the dimmer wire checks out good and it even opperates the dimmer in the radio properly.
the dimmer switch is hooked up and the wires are tight in the plug, I guess its just a bad switch...thats the only conclusion i can come to being that it flashed on that one time. I'll replace it and see whats up
good lookin out people!!!
Currently drivinig;
