OK, the rain slowed and tried to finish the EX knuckle, ?teg caliper/rotor/40-40 swap. While wrenching off the p-valve i curved the wrench over to get a better 'swing' and brushed the pos+ cable with the other end of the wrench. I did see/hear a spark
So, finished it up and bled it all nicely but when i tried to start, PMFI light staring at me.. It turns over, radio, horn works, but I didn't hear the fuel pump prime itself either. Dang-it 1/2hr before work! Checked the fuses at the shock tower, all fine. Checked under the dash, all fine?? Got out, pulled the neg off, pulled the ecu fuse, waited a few sec. and tried again. SAME thing. NO blink at all at the ecu either.. Wouldn't it short out a fuse first before frying items like the ECU? Again, ALL fuses looked fine. I even pulled them (the blade ones) checked them out with a flashlight, re-installed them. The large 40-60a ones looked good also. SO, which 'got it'?? Main relay or ECU or both? If it's the ECU, can it be 'fixed' by taking it apart and __________? I know ecu's are cheap for the D15b's but don't want to go and get one from the yard if it's something else. Again, I ran out of time before work, so I'll be trying a little shot of carb cleaner in the T/B to see if I have spark.. Maybe I fried the pump? Anywho. Good advise is appreciated E __________________
"If you can read, thank a teacher" "If you can read it in English, thank a VET" |
| Fried ECU??? | schintz04 | ECU's, Electronics, and Tuning | 6 | 10-21-2009 06:52 PM |
| fried? | INJEN78 | ECU's, Electronics, and Tuning | 2 | 02-14-2009 07:21 PM |
| Fried ecu? | jazzb18c | HYBRID -> ED-EF / DA | 1 | 09-08-2008 12:03 PM |
| Fried Ecu? | Yellowcivic | ECU's, Electronics, and Tuning | 7 | 04-25-2008 05:12 PM |
| Fried ECU | Accordturbo94 | ECU's, Electronics, and Tuning | 8 | 08-21-2003 10:19 PM |
