A friend brought me his 95 civic with a b18c1 already installed,car ran,no vtec operation,cel on. Ipulled codes had codes for vtec solenoid and knock sensor.They werent wired.Took care of that and wired vtec pressure switch too.Cel is out vtec operated once then it fell flat on its face.Wont rev over about 3500.I noticed iab wasnt wired either, will this put it in limp mode?I'm new to this kind of thing so any help would be appreciated.The cel is still out with no codes showing.This is my first post so forgive me if this is in the wrong place.I have done a lot of reading and this site has been a huge help so far with pinouts and diagrams.If anyone needs anymore info about this car I can get it for you.Ecu is a p72 and its a 5spd.My friend tells me he bought engine,trans,ecu,harness and axles as a package.
Brutal Moderator
Ride: 97 Integra LS Coupe
If you're using the original GS-R intake manifold then yeah, you probably need to wire up the IAB for it work properly...
My name is Byron.
Ride: 89' DX Hatch w/B16
You may have an auto ECU, a lot of people have the same problem because of an auto tranny ECU. The IAB being unhooked/not wired shouldnt put it in limp home mode. Try another ECU if you can get a hold of one.
^ (dont listen) Dont PM me with tech questions. I will not answer them. There is a hidden message here. "Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details." "In the dice game of life who gets the last roll?" |
I checked ecu when I got home,its a 003...by the chart thats a 5spd ecu.I was looking last nite at what I thought was the iab solenoid....in the middle of the intake....but the wire colors were incorrect....pink/blue was correct but instead of yellow/black it was solid black.Any chance someone mixed up a connector?I think I remember an evap solenoid having those color wires.
#5 |
you get the BRAKE
Just buy a chipped p28 ecu. This will eliminate your iab problem. UNLESS you really want to make it work properly. Im not a fan of those manifolds and ive actually seen them with the butterflies removed. Pretty nifty too.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
| apexi making my car go into limp mode | styless | ECU's, Electronics, and Tuning | 1 | 11-29-2005 07:54 PM |
| O2 sensor making ecu go in limp mode ? | vtecjdm | General Tech and Maintenance | 8 | 07-19-2005 12:10 PM |
| limp mode | white lude | HYBRID -> BA-BB /CA-CD | 3 | 11-16-2004 12:41 PM |
| limp mode sucks | smashed4thgen | HYBRID -> ED-EF / DA | 3 | 10-17-2003 01:09 AM |
| Ecu Limp Mode | D See 2 | ECU's, Electronics, and Tuning | 3 | 05-22-2003 08:49 AM |
