My abs light and my check engine light stay on. I have heard of "pulling codes" for both the ecu and the abs unit. How do you do this for a 95 integra?
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a> Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a> |
have you put new brakes on this car? It may just need that. Check those and if they have more than half pad left on them then let me know. I believe you have to ground a wire on that model and the check engine light will blink indicating your "trouble code". I'll check tomorrow on my integra
Rob |
Ride: 95 Honda Civic EX
over by the ecu there is a 2 wire connector I believe its brown and another color...all you need to do is stick a jumper in there and click the key to on and count the big a little flashes
http://www.myspace.com/allbottledup email allbottledup@hotmail.com or Russelchiacchia@comcast.net |
RETIRED
ABS has it's own computer. its usually in the trunk.
it will throw the main unit a code to flash the MIL, but the real info is in the abs computer |
