This is a discussion on how to convert engine to obd2 in the ECU's, Electronics, and Tuning forum
First off im not sure if this is where i should post this, so im sorry if its in the wrong area.
I have an Obd1 ls/vtec engine. B18B1,b16 head. Im driving an obd2 97 del sol. how exactly do i convert the motor to ...
| | #1 |
| First off im not sure if this is where i should post this, so im sorry if its in the wrong area. I have an Obd1 ls/vtec engine. B18B1,b16 head. Im driving an obd2 97 del sol. how exactly do i convert the motor to obd2 so i dont have to convert my car to obd1? a friend of mine said just change a few sensors,if so what sensors must i change? Thanks for any help |
| | #2 |
| Use your OBD2 harness... - The distributor will work, but the plugs are different, so you'll have to either cut-n-splice or find an adapter harness. - You'll have to swap the injectors. - You'll have to use the purge control solenoid valve that's on your stock motor. (for Emissions only) - You'll have to buy an OBD2 b-series VTEC oil pump, lower timing cover, OBD2 crank fluctuation sensor, OBD2 b-series timing gear, and an extra key. (One get used for the gear, and the other for the crank pulley itself. |
Similar Threads | ||||
| Jdm & Usdm Motor Swap Answers | civicsi1415 | HYBRID -> EG-EK / DC | 15 | 08-01-2008 12:15 PM |
| gsr obd2 engine harness | jdm00civicex | ECU's, Electronics, and Tuning | 5 | 03-04-2005 11:20 PM |
| All Swap Info for EF | Riceras | HYBRID -> ED-EF / DA | 2 | 02-07-2005 02:20 PM |
| Engine Removal Guide | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:19 AM |
| Obd2 Ecu With A Obd1 Engine | mrimport2003 | ECU's, Electronics, and Tuning | 2 | 06-11-2003 02:23 AM |
