Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
this is assumed that you already have a wideband sensor installed with a 0-5v output, and an emanage running 1.49. you also need to find and download emanage alpha tool AND make sure you have MS framework 1.1 to run it, otherwise it wont open.
oksy so i'm using the NGK powerdex wideband. it has two wires, yellow (signal) and black (ground) i had to extend the wires (solder and shrink tube!) to meet up with the emanage. now instead of buying the boost cable to plug into the emanage, we will make our own. find an old desktop computer (or ask someone) and locate the floppy drive power plug. its a 4-pin plug. cut it about 3 inches from the white plug. once that is done, use a knife and trim off the 4th pin (red) and then trim the front and sides down flat. be sure to not trim everything off the front since the plastic holds the metal pins into the plug. clip off the middle black wire. you will be left with a yellow and black wire. this is the result. ![]() now you can wire, yellow to yellow.... black to black. i used the same color wire to extend the output from the wideband. ![]() fits like a charm. ![]() you cannot have support tool and alpha tool open at the same time. in support tool - to do real time display, make sure you set in parameters to read greddy pr, and i used 9-16 (i think) for the numbers next to that. now you can open up greddy pressure sensor as a log, but its not converted from a voltage to a ratio. this is where the alpha tool comes in. in alpha tool - make sure you set and save your settings. you want to set the COM port, use boost plug, and your values. 0-5v for voltage, 9-16 for range (this is for the NGK) check other settings as you want them and save/close. connect to unit. open the logger. you have to press START for anything to work. set your throttle percentage threshhold. it will log from that TP up. make your run. you can open the graph or save the data after that. the best part about the alpha tool is that it will convert the voltage to the required AF values you need |
Von Europa
Ride: 1999 Civic EJ9, 2003 Civic EX Coupé
Nice info. I thought that connector looked the same as the floppy-drive power cable.
DIY/Howto HID Projector retrofit |
| Hondata S200 Integra GSR S300 boost rev limiter datalog | RSS-Bot | Auctions | 0 | 02-25-2008 10:33 PM |
| can a afc neo be connected to chipped ecu obd1 | ba$h | ECU's, Electronics, and Tuning | 0 | 08-07-2007 07:43 PM |
| Emanage wideband O2 Logging | Sadistik | ECU's, Electronics, and Tuning | 0 | 06-15-2007 12:44 PM |
| new plx wideband | pissedoffsol | ECU's, Electronics, and Tuning | 2 | 02-11-2005 04:02 PM |
| Battery connected backwards | assman | ECU's, Electronics, and Tuning | 9 | 03-01-2004 02:36 PM |
