Jdm Obd2 Swap Situation
Old 04-09-2003, 12:26 AM   #1
Rep Power: 0 brixity is off the scale
Thumbs up
I'm dropping a 2000 b16b into my 94 civic vx. The shop swapped the distributor, injectors, and alternator for obd1. My question is should i get a obd1 gsr engine harness so it will already have the knock sensor. Will it work right? But I want to run the obd2 type r ecu, so i'm gonna get the obd1 to obd2 coversion harness in order to run the obd2 ecu. What decisions do i have besides using an obd1 reprogrammed chipped ecu (e.g. P28) Any info will be helpful. I heard that since the ecu is JDM it will not look for those extra sensors that the usdm obd2 ecu's look for. Please help me out motor is coming soon.... I'll keep you guys posted. Also i'm new to this so holla at me. peace
brixity is offline   Reply With Quote
Old 04-09-2003, 02:42 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
the harness wont work.
its the other way around...... running an odb1 ecu on an obd2 car.
I'd run the chipped p28. jdm ecus suck, and a type r usdm ecu = $$$$$ and not any better than the p28
p28 wont look for the knock sensor, but you will have to add the evap shit or it will throw a code (ctr motor doesn't have this stock- use it from your vx.)
Please Help - del Sol Swap teezy420 HYBRID -> EG-EK / DC 23 11-06-2008 12:06 AM
obd2 to obd 1 swap Q... Tommy ECU's, Electronics, and Tuning 2 02-24-2007 01:11 PM
obd2 b18b1 swap 5th gen HatchSpeeD HYBRID -> EG-EK / DC 8 11-18-2003 10:40 PM
B20B from CRV into 92-95 Civic SI SWAP hondacivicnos HYBRID -> EG-EK / DC 6 10-08-2003 12:33 PM
OBD1 LS to OBD2 GSR Swap phlare HYBRID -> ED-EF / DA 1 09-08-2003 06:28 AM
