JDM vs. USDM and Code 13 Problems
Old 02-06-2006, 07:33 PM   #1
Rep Power: 9 geoffrey is off the scale
OK, I have Hondata installed on a Japanese P28 and is now in my 91 Civic EX with B18c and it is throwing a code 13 (PA atmospheric sensor).
My PA sensor is located on the passenger side kick panel and has always worked with the three diff. types of OBD 0 motors I have in the car, but now that I have gone OBD 1 with RYwire harness jumper I get a code 13.
Can the different origin of this P28 cause a false 13 reading or is there anything tricky like an internal ECU PA sensor like has been said from other ECUs?
geoffrey is offline   Reply With Quote
Old 02-06-2006, 11:17 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
umm, i think the Atmospheric pressure sensor is inside the ECU box on a P28, isnt it?
Anime Informant
reikoshea is offline   Reply With Quote
Old 02-07-2006, 01:43 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
just disable it with the hondata... its a useless sensor anyway.
Old 02-07-2006, 07:06 AM   #4
[quote name='pissedoffsol' date='Feb 7 2006, 01:43 AM' post='650796']
Would that be with the laptop, or is there another way to do it?
Old 02-07-2006, 10:04 AM   #5
RETIRED
yes, with the laptop, on the hondata program for your tune, you can simply check a box to disable that sensor, among others
Old 02-08-2006, 10:08 PM   #6
[quote name='pissedoffsol' date='Feb 7 2006, 10:04 AM' post='650840']
OOOps, there is a bit of a trick - the connector cable that goes btwn the Hondata box and the laptop does not fit and have to buy an adapter box to fit to the computer for a cheap 139.00
So will have to post the results from that prolly friday.
Old 02-09-2006, 01:19 PM   #7
RETIRED
what do you mean it doesn't fit? its a serial port.
if your laptop doesn't have a serial port, get a keyspan usb-> serial adapter. they are like 35 bucks
Old 02-09-2006, 09:45 PM   #8
[quote name='pissedoffsol' date='Feb 9 2006, 01:19 PM' post='651826']
The serial port on the Hondata "blue box" is two row and laptops are three rows so got that adapter piece as it is necessary. The two row are achaic (old) now.
[quote name='RubyII' date='Feb 9 2006, 09:40 PM' post='652078']
PS My P28 is European and according to tech line at Hondata does not even have a baro sensor! (It must still be defeated with the software as you said).
Old 02-10-2006, 01:53 PM   #9
RETIRED
ummm 3-row serial port? I'm A+ certified and i've never seen such a thing.
lol thats probably for an external monitor.....
serial port:
monitor port:
key span usb-> serial adapter:
http://www.keyspan.com/products/usb/USA19HS/
Old 02-10-2006, 10:32 PM   #10
[quote name='pissedoffsol' date='Feb 10 2006, 01:53 PM' post='652338']
serial port:
monitor port:
Yea that would be it, it uses the two rows. Sorry not too up on the computer terminology. Will report back if anyone cares probably Monday if I can get to it.
When I get the sensors list to drop down, no place to check off which to get rid of even though it can be highlighted.....?The only download that seems to be close on their site (Hondata) is for Hondalogger, can it be done off of this?
Old 02-12-2006, 03:53 PM   #11
RETIRED
its called "baro" in the hondata i think. its in the main software, not the daa logger
