JDM VS USDM H22A ECU and intake manifold
Old 03-10-2004, 12:49 AM   #1
Rep Power: 0 BenDejo is off the scale
I have a 93 accord with a JDM H22A swap. I live in CA and got pulled over. The cop checked under the hood gave me a ticket. I went to the smog ref to get it cleared and he said if I can prove to him that the ECU and the intake manifold are USDM he will sign off on it. The ECU is a 5 speed p13 but i dont know whether it is JDM or USDM. I have no idea about the intake manifold though. Can anyone help me out ?
BenDejo is offline   Reply With Quote
Old 03-10-2004, 01:28 AM   #2
Rep Power: 18 H22AdelSol is off the scale
If the p13 came with the jdm motor chances are its jdm. +you dont need a stupid ass usdm intake manifold, if the fucker passes it passes. If he gives you shit about it again, tell him YOU can do anything you want to that motor if it passes smog. If you have the prelude cataylitic converter, o2 sensor, usdm p13, egr and iab hooked up you should pass. The skunk2 flows better than that jdm IM and is carb legal so tell that ref hes gay. thankyou
btw, i would get the prelude intake tube+box. its got a nice restrictive filter for you to smog with+ it has a sensor in it sorta like the iab system.
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span>
H22AdelSol is offline   Reply With Quote
Old 03-11-2004, 03:28 PM   #3
Rep Power: 12 katman is off the scale
BenDejo,
the easiest way to check your P13 ecu to see if its JDM or US spec is like this:
http://www.ff-squad.com/tech/ecu/obd1.p13.check.jpg
katman is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
