Knock Sensor CEL question
Old 08-17-2005, 08:29 AM   #1
Rep Power: 12 ericL is off the scale
Ok so I have a CEL on and I took the code off of it (blinking light) and it was 23 which is a knock sensor. My car is 95 civic and the CEL code list says 23 is for 96-98 civics...i'm guessing that's b/c usdm civics (92-95) didn't have knock sensors but jdm si's obviously did..also what about 99-00 Si's those have em too..
I was reading an article on a ls/vtec build in sport compact and it said that if the ecu throws a knock sensor code that vtec will be disabled..and mine is engaging fine (about 6000rpm). First off is this true? And if so how can i find out what is really wrong if it's not what the ecu says it is...
On a side note the knock sensor CEL suprised me b/c the IACV sensor is hooked up but the hoses to/from it are not..so i thought it would have been that...
Car: 95 civic, jdm b16a sir2, p30 ecu
ericL is offline   Reply With Quote
Old 08-17-2005, 12:02 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
what car?
what motor?
what computer?
you lost me
Old 08-17-2005, 12:42 PM   #3
Lol sorry i got carried away with description and forgot the most important part:
95 civic, b16a sir2, p30 ecu...
Old 08-17-2005, 12:57 PM   #4
RETIRED
ok, and did you run the wire from the back of the block to trhe ecu?
Old 08-17-2005, 01:04 PM   #5
the knock sensor wire? yea it's wired to the ecu, my bad if that's not what you're talking about
Old 08-17-2005, 01:20 PM   #6
RETIRED
yeah thats what i'm talking about.
ok, so everything should be hooked up correctly.
and you're throwing a code for knock....
so either:
A- the sensor itself is bad
or
B- you're knocking REAL freakin bad... perhaps a timing issue
or
C- you really didin't wire it up right to the right pin, or it has a shitty connection.
Old 08-17-2005, 01:38 PM   #7
Right, i know what could be wrong if it actually is a knock sensor...i'm trying to verify (1) if VTEC will or will not engage with a bad knock sensor, (2) why code 23 is only listed for 96-98 civics...
I should also say that it is not always on once you really rev the car and/or it warms up it will come on...
Old 08-17-2005, 01:40 PM   #8
RETIRED
1) not sure. i always disable that useless freaking sensor in a chip tune
2) the 5th gen civics don't have one... only the b-series. and besides, thats just a generic list for assumable STOCK cars.
Old 08-17-2005, 01:42 PM   #9
Gotcha, I just wanted to check b/c 99-00 civic si wasn't listed for code 23...
Is there a way to test the sensor itself if it's bad? I know for like ECT sensors or TPS you can test with a multimeter..
Old 09-05-2005, 01:58 PM   #10
Rep Power: 0 HondaVTEC93 is off the scale
found out that mine was hooked up w evap plug...so look at that.
HondaVTEC93 is offline   Reply With Quote
Old 09-06-2005, 12:47 PM   #11
Originally posted by HondaVTEC93+Sep 5 2005, 01:58 PM--><div class='quotetop'>QUOTE(HondaVTEC93 @ Sep 5 2005, 01:58 PM)</div><div class='quotemain'><!--QuoteBegin-ericL@Aug 17 2005, 12:42 PM
Is there a way to test the sensor itself if it's bad?* I know for like ECT sensors or TPS you can test with a multimeter..
[/b][/quote]
So the wrong plug was used and was throwing a code? The plug on mine is green and has two slots for wires, one is plugged.
I tested the wire for continuity and it was fine. THe gauge of wire used was 16 ga, is that too thick (causing a CEL?)
Old 09-12-2005, 06:33 PM   #12
bump
Old 09-12-2005, 06:53 PM   #13
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
as far as you vtec engaging question....yeah vtec will still engage. My vtec engaged when my knock sensor wasn't hooked up! i later took a closer look and hooked it back up.
LS/VTEC with pw0
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 09-12-2005, 07:47 PM   #14
Aight well i noticed that the wire wasn't very far in the clip (that goes into the ecu) so i took it out and put it in a little further and now the CEL is gone. Hopefully it's gone for good, thanks for all the feedback
Old 09-13-2005, 12:54 AM   #15
RETIRED
option C takes the cake
