Hi!
I need aid on a supercharger project - mainly the ECU issues I have. Is it possible to burn a chip which is "universal" or "as universal as possible" for boosting the B16A, if I use a spesific injector/fuel pump setup? Referring to my thread in the "Forced Induction"-section for further info about the project. Thanks! /Boomboxx |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
as universal as possible = a basemap
you should be able to find something close... but unless you have means of monitoring your air:fuel i wouldn't go beating on it with just a basemap... __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
This sound promising. Where do I find these basemaps? Can someone here make them for me if I specify the injectors and fuel pump? Hmmm.
If so, I'm almost in goal, aren't I? ![]() I plan on using a wideband O2 and just measure the output (eg. if it's around 2,5V I'm happy), but I must read more on this. Maybe it isn't even possible. ![]() /Boomboxx |
RETIRED
if your b16 is stock, your best bet without tuning is to go to Hondata - Honda ECU Modification and Enhancement
it's expensive, but they have tuned maps for the jackson charger on the old s200 series |
#5 |
Well, I went there, but didn't find much. I'm a little blind, maybe... But anyway, I'll nag a little more!
![]() What kind of ECU do I have, exactly? I found somewhere on the net which had an overview of the different ones, but now I've lost it... Sorry for me posting in two threads, I'm a little inpatient, I'm afraid... Also, I'm not that sure which thread everything belongs in. You may delete one if you want to ![]() |
#7 |
HS Troll...And Mod
Ride: 2001 Honda S2000
we are probably that place (check the reference section) that had the ecu list.
as pissedoffsol said, get hondata s200, it has maps for the jrsc on a stock b16. __________________
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
| Supercharging the B16A in a '93 Del Sol? | Boomboxx | Forced Induction | 6 | 08-16-2006 05:28 PM |
| Project b16a 85 integra | dipstk | HYBRID -> ED-EF / DA | 3 | 05-09-2006 02:59 AM |
| supercharger on jdm b16a? | hondadriver | Forced Induction | 4 | 10-03-2004 01:11 AM |
| B16A Variants | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:31 AM |
| My B16a Build Project !no 56k! | D See 2 | Members' Lounge | 29 | 05-07-2003 02:08 AM |
