Need Help For Volt Meter Gauge!
Old 03-27-2003, 04:50 PM   #1
Rep Power: 19 ovcrash is off the scale
Unhappy
Hi,
I would like to know where do i connect the wire of my Volt Gauge Meter that i got from AcAutotechnic? I have a red wire and a black wire for the volt gauge.
And i have a Red wire and a Black wire for the lights in the volt gauge.
So where and how do i connect all of this?
Thanks alot for your help.
BTW: i have a 1997 Civic Hatchback.
ovcrash is offline   Reply With Quote
Old 03-27-2003, 04:52 PM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
i'd assume you'd tap into anything with 12 volts when the key is on, and then ground the black .
get a voltmeter and go to the fuse box and there should be some leads that are keyon ignition off
pills_PMD is offline   Reply With Quote
02 Sensor wire on Air/Fuel meter turns it off? hatchboy HYBRID -> ED-EF / DA 11 11-02-2003 05:50 PM
A/F ratio meter rudeludenotmeanthough General Tech and Maintenance 15 09-15-2003 08:07 PM
Apexi Rve/Speed Meter progressivedrunk ECU's, Electronics, and Tuning 1 09-03-2003 10:38 AM
Air/fuel Meter Vs Egt Meter JDMSpecAccordSir-T Forced Induction 5 06-19-2003 02:11 AM
Auto Meter Tach JDM6thGen Parts: For Sale/Trade/Wanted 1 05-05-2003 11:48 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
