Need to identify an ECU
Old 11-17-2004, 12:49 PM   #1
Rep Power: 26 projectxspeed is off the scale
Send a message via AIM to projectxspeed Send a message via Yahoo to projectxspeed
Is there a way to tell by the numbers on the side of a USDM ecu to tell if its a manual or auot? I am looking at a getting a p28 from a yard, and I don't want them to give me an auto when I need a manual.
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a>
Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a>
projectxspeed is offline   Reply With Quote
Old 11-17-2004, 12:58 PM   #2
1995
Old 11-17-2004, 01:00 PM   #3
well I would if I could but the ecu has already been pulled. Its just chillin on a shelf; its hard to look at the car when its not there.
Old 11-17-2004, 01:28 PM   #4
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
http://www.hondaswap.com/~pills/autotomanual.html
First, let's find out if we have an automatic, or a 5 speed ECU. If you don't want to plug it in and throw code 19 (automatic trans lockup solenoid) to find out it is an automatic ECU, then look at the code on the side. If the second to last number is a 5, then you have an automatic ECU (for OBD-1 USDM ECUs). If the 2nd to last # is anything but a five you have an ECU for a 5 speed. If you have a jdm obd-1 ecu, look at the last 3 digits: 900 or 901 will be an automatic.
Old 11-17-2004, 07:53 PM   #5
Thanks for answering my question
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
