Facebook Twitter
OBD-1 into OBD-2 Accord help
This is a discussion on OBD-1 into OBD-2 Accord help in the ECU's, Electronics, and Tuning forum
So I swapped a 95 accord sohc-vtec into my 97 accord se (non-vtec). The swap was out of necessity, so I don't care if it has "vtec" or not. I converted the obd-2 engine harness to match the obd-1 distributor , swapped the egr valves ...
Old 05-30-2007, 03:06 AM   #1
Default OBD-1 into OBD-2 Accord help
I converted the obd-2 engine harness to match the obd-1 distributor , swapped the egr valves and swapped out the injectors. Other than that everything was plug'n play.
Now I have codes 71,72 and 74 while using the obd-2 ecu. I wanted to stay simple and cheap and thought this would work fine... but I don't know why it's throwing these codes... the engine seems to run fine (I don't hear any detonation or anything), although the power band does seem a little weak in the upper rpms...
any help would be greatly appreciated.
sleepn_accord is offline   Reply With Quote
Old 06-02-2007, 01:49 PM   #2
I'll throw out my 2 cents here, which is if you can get the ecu from the 95, get that and get a crossover cable to go from obd-2 to obd-1. As we all know obd-2 added more sensors for higher emissions control and the obd-1 motor may not have all of them. I know your trying to stay as cheap and simple as possible, but I think that would be the best bet. What motor did you have in there vs. the one you have now? We know its vtec vs non-vtec but you know what I mean? -Gary
P7ank5te7 is offline   Reply With Quote
do help me identify my accord type please fatblack4 Members' Lounge 1 09-05-2006 09:20 AM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 12:03 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 07:48 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 03:43 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 09:31 AM
© 2001-2013 HondaSwap.com
