OBD1 Ecu converion
Old 11-10-2002, 02:51 AM   #1
Rep Power: 30 SolReaver is off the scale
Can a obd1 p75 automatic ecu be converted to a manual ecu relatively easy? If so how do i go about doing that.
<a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a>
I will paypal $8 to the first 3 people to complete the offer, PM me if interested.
SolReaver is offline   Reply With Quote
Old 11-10-2002, 02:55 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
it involves soldering and stuff....
Old 11-10-2002, 03:08 AM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 527 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
i think the conversion you need is called eBay... its pretty easy .. you put your ECU up on there and sell it to someone then you take the money you recieve and convert it into the right ECU... its really a pretty simple process... i can get you more detailed instructions if you wnat them hehehehe
МОΛΏΝ ΛΑΒΈ
Old 11-10-2002, 03:08 AM   #4
RETIRED
lol- dick
Old 11-10-2002, 03:24 AM   #5
LMAO!!
Yeah i kinda figured it would involve that If someone knew the actual wires to solder or what to do...
and esolsi- thats what im going to do...theres an obd1 ecu that i need but its an auto, and its like 15 bucks with 10 hrs left
So the final question is- can it be done???
Old 11-10-2002, 03:31 AM   #6
RETIRED
its not wires- its chips and capacitors
Old 11-10-2002, 10:40 AM   #7
Ride:  06 Chevy Silverado
Rep Power: 83 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
Its one resistor that needs to be soldered. Your car will run with an auto ecu but the cel will be on. I can find out which resistor it is. I believe its on the hondata website.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
Old 11-10-2002, 11:09 PM   #8
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
between the ROM and the side of the ECU are a number of jumper resistors labelled with RP. remove RP17 and install a jumper across RP18.
that will convert a usdm p75 obd1 ecu from manual to auto
pills_PMD is offline   Reply With Quote
Obd2 Car Obd1 Engine & Wiring SpeX ECU's, Electronics, and Tuning 16 01-10-2009 09:58 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
Converting from OBD0 to OBD1 Guy HYBRID -> ED-EF / DA 5 10-25-2004 11:08 PM
OBD1 LS Motor and ECU in 99 Civic LX... SlidewayzFC HYBRID -> EG-EK / DC 3 10-12-2004 01:03 PM
What obd1 computer is compatible w/98 dx non-vtec aaronblake98 ECU's, Electronics, and Tuning 3 02-17-2004 07:49 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
