Obd2 B18b Eg Wiring Help Needed Please
Old 04-08-2003, 04:37 PM   #1
Rep Power: 15 nwisehart is off the scale
I am doing an obd2 b18b1 engine swap in my 1992 civic and I was wondering what wires need to be added or swapped. I am running an obd1 pr4 ecu also. I see that the ecu doesnt have a knock sensor and neither does he engine so that eliminates that wire. Do i need to run the wires for the evap purge power and the evap purge solenoid. I cant find any reference that tells me exactly what to do. All the resources that i have found are for an obd2 b18c1 in an eg, and not an obd2 b18b1 in an EG. From what I have read the B18b1 doesnt have the IAB either. Please correct me if I am wrong on anything and please steer me in the right direction.
nwisehart is offline   Reply With Quote
Old 04-08-2003, 04:44 PM   #2
Rep Power: 30 SolReaver is off the scale
ok do this-
remove old engine wire harness from the connectors at the shock towers
plug pr4 ecu into your (civic) wiring harness inside the car
drop teg motor in
plug all the plugs to the exisiting firewall wire harness, at the point where you removed the connectors of the old wire harness
there will be a couple plugs on the driver side left hanging, dont worry about those
the sensor on top of the IM, you can either plug the connector in or leave it hanging, it doesnt matter
same goes for the hoses that are just hanging there
fire the motor up and begin saving for a turbocharger
good luck
<a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a>
I will paypal $8 to the first 3 people to complete the offer, PM me if interested.
SolReaver is offline   Reply With Quote
Old 04-08-2003, 04:52 PM   #3
Its that easy huh. Man I have been searching for weeks now. Thanks a lot. That must be why there arent many resources for this exact swap, because there is nothing to it. Thanks
Obd2 Car Obd1 Engine & Wiring SpeX ECU's, Electronics, and Tuning 16 01-10-2009 09:58 PM
obd2 wiring harness or eg ex civic harness cooper ECU's, Electronics, and Tuning 9 09-01-2008 11:11 AM
Wiring Help Needed bigjussin HYBRID -> BA-BB /CA-CD 2 02-19-2004 10:47 AM
obd1 ecu and obd2 skunk 2 wiring harnass hondacivicvtec99 Parts: For Sale/Trade/Wanted 2 07-25-2003 09:01 PM
Wiring Up B18b In 1993 Cx grinnis HYBRID -> EG-EK / DC 2 05-06-2003 03:52 AM
