ok i have a 92 civic hatch and im putting a h22 into it. i have found a good deal on a h22 that is a 97 which is obd2. what do i have to do to the harness under the hood to make it work??? also can i run a obd1 h22 ecu on the obd2 h22 motor??? please let me know asap! thanx so much!!
![]() __________________
92 Civic hatch: 95 jdm h22 swap 1000lb rear springs 6 puck clutch disc with 2600lb pressure plate gutted..... working on as you read this, turbo set up.. ...need i say more...? |
RETIRED
be prepared to spend a pretty fortune for an obd1 h22a ecu without an imobilizer!!!!!
350 is average price for just the ecu other than that, you use your civic harness, swap plugs where necessary, run wires for vtec if necessary, and IAB butterflies on the IM, other than that its a normal h22 swap. |
sorry im ignorant...what do you mean by swaping plugs? it already is wired for vtec.
WRX Sellout
Ride: 2002 WRB Impreza WRX
I've seen OBD1 P13 ECU's go for less than that, you just have to hunt for them. B is right though, there are people out there who charge a kidney for them.
This space left intentionally blank. |
#5 | |
RETIRED
conversely, if you use the h22 harness, your ecu won't plug in without swapping plugs/conversion harness. so you have to physically cut the sensor off the h22 harness, cut the plug off the civic harness and put the h22 plug on the civic harness, matching up wires absed on your TWO helms manuals- one for your car, one for your motor. |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| h22 mounts for 92-95 civic | minirek | Parts: For Sale/Trade/Wanted | 9 | 02-23-2004 11:55 PM |
| obd2 b18c1 into a 5th gen civic | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:12 AM |
| Decoding VIN Numbers | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:48 PM |
| Anyone here? | 2000Si | Members' Lounge | 14 | 12-09-2003 11:55 AM |
