obd2 im + obd1 harness
Old 03-09-2004, 12:27 AM   #1
Rep Power: 21 98integrals is off the scale
Send a message via AIM to 98integrals Send a message via Yahoo to 98integrals
will an obd2 inake manifold work with an obd1 wire harness?
i know i will need the obd1 distributor.
as soon as i get mounts and my tranny the swappage will start on the hatch
red hood>red valve cover
98integrals is offline   Reply With Quote
Old 03-09-2004, 05:33 PM   #2
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
bump for jack.
As I told Jack on AIM, I wasn't 100% sure, but I belive that he has to run obd1 injectors, obd1 dizzy, and other then that, I have no clue.
Anyone else?
Collin
Material Science and Engineering
Michigan Technological University
Old 03-09-2004, 06:48 PM   #3
Rep Power: 12 truent is off the scale
Send a message via AIM to truent Send a message via MSN to truent Send a message via Yahoo to truent
obd2 intake manifold will work fine on obd1 harness.. iac needs to be changed.. it's located above the fuel rail on 96+ and it's a different type of plug.. so extend and change that..
the injectors.. either use 92-95 injectors to match the harness or change the injector plugs on the harness to match 96+ injectors..
alternator plug is diff.. always just used the 92-95 one.. but im sure 96+ will work you just gotta change the plug
i'd use a 96+ distributor.. 92-95 legs are diff.. but as far as i know 96+ will work fine with 92+ ecu
96+ distributor plug is different and combined into one.. i think thats all as far as the engine goes..
in otherwords.. easy peasy lemon squeezee
get at me
--truent
aim: gettruent
truent is offline   Reply With Quote
Old 03-09-2004, 10:36 PM   #4
sweet thanks.. im a n00b all over agian .
anyways my harness is shot strait to hell and back so im going to need another one. the one that came on my b20 is cut in about 90 places, but i found an obd1 teg uncut harness local for like $40. that harness will work if i get the injectors and distributor.
here is what i have so far
obd2 b20
obd1 p74 ecu
and im getting an obd1 ls harness.
thanks for any and all help/n00b bashing lol.
Old 03-10-2004, 10:47 AM   #5
Rep Power: 19 radnulb is on a distinguished road
Send a message via ICQ to radnulb Send a message via AIM to radnulb
FYI, OBD0, OBD1 and OBD2 LS distributors all share the same bolt pattern. You can use an OBD2 distributor with an OBD1 car, but the main problem is the lack of tachometer output on the distributor. The easiest way around this (that I know of) is to use an aftermarket ignition amp (MSD 6A, Crane, ... ...) that has a tachometer output. The easy thing without any doubt is to get a 92-95 LS distributor, but if that's not an option following the installation instructions for the spark box carefully will solve the issue too.
You can't use a B20's intake manifold due to its shape - you need an OBD1/OBD2 B18 manifold
Good luck.
PGMFI.org founder and DIY ECU tuning advocate
Just say no to rice...
radnulb is offline   Reply With Quote
Old 03-10-2004, 11:22 AM   #6
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
if you use the b20 intake manifold you will have to run with out a hood or cut it out get my drift get any b series maniford just stay a way from the gsr
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 03-10-2004, 11:49 AM   #7
Good luck.
i know i cant use the b20 im cause its like 10" tall so i gave it to a friend to make some ITBs out of haha. thats why i was asking if an obd2 im would work cause i will prolly just use his obd2 b18b im.
thanks for the help guys
Obd2 Car Obd1 Engine & Wiring SpeX ECU's, Electronics, and Tuning 16 01-10-2009 09:58 PM
h22 obd1 obd2 ? can i do this? imprt92 ECU's, Electronics, and Tuning 2 04-07-2004 06:36 PM
OBD2 or OBD1? acolvard HYBRID -> BA-BB /CA-CD 4 12-22-2003 06:07 AM
OBD2 or OBD1? acolvard ECU's, Electronics, and Tuning 2 12-10-2003 05:17 PM
obd2 to obd1 harness h22poweredgsr HYBRID -> EG-EK / DC 1 09-18-2003 04:29 PM
