Obd2 To Obd1 Conversion
Old 03-29-2003, 06:29 AM   #1
Rep Power: 15 Pewble is off the scale
Send a message via AIM to Pewble
Post
I need to convert my OBD2 to OBD1, For two reasons. One is I recently installed a High-flow Cat, and I need to bypass the O2 sensor so my check engine light is disengaged. Second reason is because instead of buying a simulator to emulate this effect, OBD1 will not check this, and then conversion can offer a horsepower advantage because OBD1 is better and because I am getting a Skunk2 / Or Mugen Chipped ECU combined with the OBD1 conversion ( The chip converts and acts as an ECU, and is a P28 chip ).
Another question...
Mugen or Skunk2 ECU program? which is better? .... my engine has stock internals ... THANKS.
Pewble is offline   Reply With Quote
Old 03-30-2003, 07:30 PM   #2
Rep Power: 20 AllMotorMonster is an unknown quantity at this point
Are you asking a question or making a statement?
Stock internals? = Stock P30 chip.
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a>
AllMotorMonster is offline   Reply With Quote
Old 03-30-2003, 08:41 PM   #3
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
Pewble Posted on Mar 29 2003, 06:34 AM
Another question...
first i think you should change your name to "newble" and then repost your question in english. thanks
saturn_boy96 is offline   Reply With Quote
Old 03-31-2003, 07:44 AM   #4
Rep Power: 14 Vexamus is off the scale
ok, firstly, highflow cat wouldn't cause O2 sensor codes, the o2 sensor lies before the cat anyway(I ran with a straight header after my swap with no codes...)
Secondly, to convert to OBI, you're going to need a conversion harness, an OBDI ECU, an OBDI distributor(because of the differences in the Hall Effect sensors located in the block and distributor housing).
I think you need to do some more reading before you spend money.
If you've got stock internals, then don't waste you're money on a JUN or Mugen chip. If you wanna spend money on a tunable ecu, buy a stock P30 and drop a Hondata in it. You'll be much happier with it in the long run.
JUN and Mugen chips are designed for highly modified Type-R engines, that's a B18C5 with internals and a valve job.
95 Accord Euro R Hybrid
T series 5 speed with LSD
No boost, No bottle, Pure throttle.
Accord of Doom:
Vexamus is offline   Reply With Quote
Old 03-31-2003, 09:35 AM   #5
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
first off, forget the mugen and jun and skunk2 chips...
you'll run soooo rich it's ridiculous.. .want proof??
click here for a skunk2/p30/p61 comparison
you;'l run like 11:1 a/f which = slow ass shit yO.
i agree with the obd2 --> obd1 conversion, but i suggest a hondata chipped p28.
i can write you the chip if you need it and probably get you pretty close, as i've spent time and money on a dyno tuning my b16 with hondata.
pills_PMD is offline   Reply With Quote
Old 03-31-2003, 11:32 AM   #6
Rep Power: 20 TRuggiero_ is off the scale
I can tell you exactly how to build an 02 sensor simulator if you want. It'll cost about 10 bucks in parts, or I can make one for you.
This is my civic. There are many like it, but this one is mine.
My civic, without me, is useless. Without my civic, I am useless.
Think your Cool? Take the <a href=\'http://www.sailinganarchy.com/general/2002/cool_test.htm\' target=\'_blank\'>test!</a>
TRuggiero_ is offline   Reply With Quote
obd2 to obd1 conversion nwisehart HYBRID -> ED-EF / DA 1 02-19-2004 11:13 PM
obd1 to obd2 alternator conversion SixtySecondAssassin HYBRID -> EG-EK / DC 3 12-25-2003 07:55 PM
OBD2 to OBD1 conversion gabspeed ECU's, Electronics, and Tuning 0 10-09-2003 08:26 AM
New P28 Chip, Obd2 To Obd1 Conversion Pewble HYBRID -> EG-EK / DC 2 03-31-2003 01:51 PM
B18b Swap + Obd2 To Obd1 Conversion Baker HYBRID -> EG-EK / DC 5 02-28-2003 11:11 PM
