I get 18 miles per gallon mpg with this combo with a del sol
would I get better economy if I picked up the ecu specifically for this car from honda? its got the header and intake/throttle body of a d16y8 I think the ecu is the P08j just to clarify, I bought the Car with that ECU and Engine Combo, Is it worth getting a P08J put in, will it put my fuel economy up? does the displacement make a major difference? where should I get the p08j? how much is reasonable to pay? Last edited by puttockc; 06-24-2008 at 06:35 AM. |
My name is Byron.
Ride: 89' DX Hatch w/B16
You should always run the ECU that goes with the car, swapping ECUs will do nothing for you, and in most cases (like yours) is worse for your car.__________________
^ (dont listen) Dont PM me with tech questions. I will not answer them. There is a hidden message here. "Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details." "In the dice game of life who gets the last roll?" |
#3 | |
Reverend Awptickes
Ride: 1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Uh, dude. A p28 is designed for a d16z6. The only way you'll see a power improvement swapping to a p28 is if you are swapping to a chipped p28, or you have a d16y8. Your d15b7 is running way too rich. Swap it out before you screw up the piston rings, then change your oil. Bottom line: Get the right ecu (P08), or chip it with the proper basemap. |
Brutal Moderator
Ride: 97 Integra LS Coupe
This thread is hella confusing. I'm assuming some posts got deleted?
![]() __________________
#6 |
Ride: 88 Honda Civic HB
Is it a D15B VTEC? If so, a P28 would run that fine. If you're getting 18MPG, I'm going to say there's something else wrong with your car.
#7 |
i have to agree. the p28 should be able to run a D15B vtec fine.. just a slight drop i mpg and a little loss in performance due to the fuel and timing maps being off from eachother. but should still get around 30 mpg or better with the d15 p28 combo. Something else has to be wrong with the vehicle.. Are you still runing the four wire o2 sensor with the p28? does it run rough?
| The Hybrid Argument (fuel economy vs upkeep) | Silverchild79 | Members' Lounge | 36 | 05-12-2008 07:41 PM |
| Fuel Economy Problem (help me troubleshoot) | Silverchild79 | Other Vehicle Discussions | 16 | 01-25-2007 05:16 PM |
| D15B ECU vs B16A ECU fuel mapping ? | natecspecr | General Tech and Maintenance | 1 | 04-17-2006 10:14 AM |
| driving for fuel economy | bcman | Racing and Driving Techniques | 15 | 08-12-2004 12:18 AM |
| Fuel Economy | kimchimik | General Tech and Maintenance | 11 | 10-21-2002 03:37 PM |
